Author: Subject: chain drive
misty1
posted on 15/8/16 at 09:09 PM Reply With Quote
chain drive
hi all
does anyone know how to put together a chain drive diff as im going to put a bike engine in the car
daniel mason
posted on 15/8/16 at 09:57 PM Reply With Quote
What car?
misty1
posted on 15/8/16 at 10:06 PM Reply With Quote
haynes roadster
daniel mason
posted on 15/8/16 at 10:11 PM Reply With Quote
Front engined?
daniel mason
posted on 15/8/16 at 10:19 PM Reply With Quote
Douglas Anderson at westgarage engineering if it's mid engined although in a Haynes chassis I can't understand why you'd need a chain diff unless your going to chop the car to make room.
In which case a mid engined chassis like the riot on eBay would be better base to start
misty1
posted on 15/8/16 at 10:21 PM Reply With Quote
ill get on to that now many thanks
misty1
posted on 15/8/16 at 10:25 PM Reply With Quote
wow did you see the prices |||||||||||||||||||||||||||||||||| its only a past time im doing it and im on the pension as well
daniel mason
posted on 15/8/16 at 10:27 PM Reply With Quote
Try quaife then and make sure your sat down!
misty1
posted on 15/8/16 at 10:32 PM Reply With Quote
O dear will try them tomorrow thanks
daniel mason
posted on 15/8/16 at 10:38 PM Reply With Quote
I run the quaife in the Jedi but it's a properly designed mid engines racing car. How are you squeezing one into the back of a kit car chassis and retaining wheelbase and bodywork? Have you got any pictures?
Slimy38
posted on 16/8/16 at 05:53 AM Reply With Quote
Normal bike engine in a Haynes is run from the front with a propshaft to get the power to the rear. That way you can use a normal diff (and keep the price down). The only thing you need is a propshaft adapter which can either be made from a front sprocket or can be bought as a bolt on piece.
40inches
posted on 16/8/16 at 09:41 AM Reply With Quote
This is the tried and tested route. No need to reinvent the wheel
You will need a prop adaptor and 2 piece prop, connected to a Sierra diff.
Prop adaptor fitted
Prop adaptor fitted
ReMan
posted on 16/8/16 at 10:44 AM Reply With Quote
Have you considered a reverseing solution?
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
misty1
posted on 16/8/16 at 11:56 AM Reply With Quote
no i have not i think i will go back to the drawing board and have another think about what i am doing
40inches
posted on 16/8/16 at 12:59 PM Reply With Quote
What part of the UK do you live in? There is bound to be someone close who has a BEC for you to look at.
misty1
posted on 16/8/16 at 01:11 PM Reply With Quote
hello
i live in northern ireland thanks
daniel mason
posted on 16/8/16 at 01:33 PM Reply With Quote
Explain exactly what you are wanting to do and in what chassis!
You've posted in the mid engine section but said you're using a haynes roadster chassis and a chain diff?
Surely you weren't intending to run the engine in the front but chain driven to the rear? Where we're you planning on running the chain? As the front sprocket would be way off the centre line of the car?
Or were you planning to butcher the chassis and run it mid engined?
MK9R
posted on 16/8/16 at 09:07 PM Reply With Quote
I have a very successful front engine chain drive MNR race car so don't let the none believers put you off. I run 2 chains with an idler in the middle. I used a rs turbo viscous LSD unit mounted in custom alloy blocks and bearings. You could do the same with a Mazda mx5 LSD or Sierra, pretty cheap option and easy to do.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
