Author: Subject: Noisy fuel pump
leon51274
posted on 12/9/16 at 02:44 PM Reply With Quote
Noisy fuel pump
Good afternoon chaps
My fuel pump seems to be getting bloody noisy recently and thought before I start farting about blathering myself in fuel that I'd upload a video to see what you guys thought.
https://youtu.be/dvXDQKBuhVs
hopefully this link will work as I've never uploaded a video before.
Leon
mcerd1
posted on 12/9/16 at 02:51 PM Reply With Quote
leon51274
posted on 12/9/16 at 02:56 PM Reply With Quote
Thank you mcerd1
posted on 12/9/16 at 04:02 PM Reply With Quote
I don't think that's right - no experience of that type of pump myself, but I know that noise would drive me nuts!
Can you get the cover off? Or is there an adjusting screw somewhere? It sounds like a car horn that's gone out of adjustment...
big-vee-twin
posted on 12/9/16 at 04:22 PM Reply With Quote
Shouldn't that type of pump ( high pressure) be below the bottom of the tank, they like fuel to be gravity fed rather than having to suck, perhaps it's on its way out because it's mounted too high?
http://www.triangleltd.com
leon51274
posted on 12/9/16 at 05:06 PM Reply With Quote
Its a sealed unit so no way of getting into it.
This is what it was like when i bought it and its run ok for the last 2 years but just seems to of got bloody loud. Problem is I wear a helmet and ear plugs when driving so not really noticed it getting like it is now.
I have a spare facet, are these happy being mounted the same as my current one?
gremlin1234
posted on 12/9/16 at 06:58 PM Reply With Quote
fuel pumps shouldn't make that much noise,
but it seemed the noise stopped as you were about to start the car, ie it got up to pressure and stopped pumping (this is good)
can you try powering up the pump without the engine running to confirm this.
after that its see why it makes so much noise on fairly light duty,
what pump is it, my guess is a bosch 044
mini-sprite
posted on 12/9/16 at 07:13 PM Reply With Quote
As a test i would remove it from its high position and get it as low as possible. That sounds like it struggling and sucking air in. Does it maintain fuel pressure when driven?
Paul
When i buy car parts i go on the premise that 'it is easier to beg for forgiveness than ask permission'
gremlin1234
posted on 12/9/16 at 07:20 PM Reply With Quote
Paul
very similar to my thinking,
perhaps its the first time its been run with low fuel in the tank.
these type of pumps require 'flood fill' else they just try to pump vapour
leon51274
posted on 12/9/16 at 07:50 PM Reply With Quote
Thanks for the replies lads.
Yes the fuel pump fires up when you turn the ignition on then cuts off once it's reached pressure.
I get no hesitation when giving it the beans it's just bloody loud but then the exhaust note kicks in and I can't hear a thing then!
The fuel is fed by a built in swirl pot on the tank so I'd be surprised if it was sucking air.
I could try and lower the pump but it would be a bit of farting about with pipes etc, but I do have a round facet fuel pump that would be an easy replacement and they don't require to be any lower, just vertical.
gremlin1234
posted on 12/9/16 at 08:14 PM Reply With Quote
not air in the fuel, but possible cavitation/ vapour lock
see
http://fuelab.com/what-is-cavitation-how-to-avoid-it/
mark chandler
posted on 12/9/16 at 08:33 PM Reply With Quote
It not designed to pull, only push so placing above the tank causes cavitation.
Place it at floor level, TBH it sounds like it's on the way out now, get a spare ready to swap out when it dies.
leon51274
posted on 12/9/16 at 08:39 PM Reply With Quote
Interesting. I'll certainly check the temp of the pump when i get to work tomorrow morning.
see
leon51274
posted on 12/9/16 at 08:40 PM Reply With Quote
Would the facet be a good replacement?
mini-sprite
posted on 12/9/16 at 08:44 PM Reply With Quote
The facet one is not a hp pump so not really unless you are running carbs which i doubt as you already have a hp pump.......(the noisy one)
Paul
leon51274
posted on 12/9/16 at 08:49 PM Reply With Quote
I'm running jenveys but I do have an in line pressure valve so not sure if they require hi flow? Obviously I'm not much of a mechanic!
Paul
mini-sprite
posted on 12/9/16 at 08:54 PM Reply With Quote
Paul
If your running Jenvey ITB (individual throttle bodies) then your fuel injection which requires a HP (high pressure) pump the Bosch 044 as stated in a post above is what you want. Be careful buying from ebay though as there are loads of spurious knock offs.
Paul
leon51274
posted on 12/9/16 at 08:57 PM Reply With Quote
Thanks Paul
Paul
Paul
chris
posted on 12/9/16 at 10:37 PM Reply With Quote
I am in the midst of converting over to throttle bodies and have just bought an ln tank swirl pot and high pressure pump originally fitted to the land rover v8 bargain at £40 off the bay not fitted it yet so might be a pile of poo
