Author: Subject: acewell tacho
Mark100
posted on 24/9/16 at 12:47 PM Reply With Quote
acewell tacho
im running zetec st170 and i have nodiz and vvt controller with and acewell
instructions that says to wrap wire round the plug lead or connect to the cdi 1 port
and have number 2 connector on the back of the nodiz that says its for tacho
but nothing works
wrapped wire round lead 4 times 6 times 8 times etc etc
plugged in to nodiz still nothing no reply from nodiz forum either
any ideas im at the end of my rope with this
any pics of what youve done would be helpfull
thanks
russbost
posted on 24/9/16 at 01:27 PM Reply With Quote
The Acewell needs to "see" a trip voltage, something switching effectively. Whatever type of coil, coil pack or switching system etc. you have it should work from the switched side of the coil, doesn't matter whether that is one coil for 4 cylinders or an individual coil for each cylinder (you would obviously only connect to one!). It can also pick up from a switched injector.
I don't understand why it isn't working from wrapping the Acewell wire around the plug lead though, normally the high voltage running through the plug lead creates a voltage as it passes thro' the "coil" of wire you have wrapped around the lead & acts as an inductive pickup, you are using the slim yellow wire supplied with the Acewell to wrap around the plug lead?
Offhand I don't know what the connector on the back of the nodiz actually puts out, so no way of knowing whether or not you would expect it to work from that connection
Mark100
posted on 24/9/16 at 01:34 PM Reply With Quote
Did not get a yellow wire i got a grey and white wire in the loom that says tacho .....?.. should there be a wire or something that goes on to this ..??? Cheers russ
russbost
posted on 24/9/16 at 02:30 PM Reply With Quote
what Acewell have you got?
Mark100
posted on 24/9/16 at 05:15 PM Reply With Quote
7659
russbost
posted on 25/9/16 at 01:02 PM Reply With Quote
Check your wiring diagram, the tach wire is a yellow wire on the main plug which has black, brown, red, blue & pink/white cables also on that plug.
The grey/white wire when earthed will bring on the "H" light for high as in a high/low transfer box as you find on some farm quads, I've never seen an Acewell loom with markers on individual wires, so no idea where your tacho identification of that wire has come from???
Would explain why it doesn't make the tacho work tho' .................
posted on 25/9/16 at 01:04 PM Reply With Quote
Has the Nodiz got a tacho output?
Just connected my acewell to the ecu output and all was well..
Mark100
posted on 25/9/16 at 06:17 PM Reply With Quote
i got a full car loom with the acewell wired in and instructions that say white grey wire is tacho there are a few others wires for windscreen wipers etc that I aren't using so I think ill see if it works with one of them and its just misslabled if not its time to start stripping the insulation I think
russbost
posted on 26/9/16 at 07:03 AM Reply With Quote
You need to trace wiring back to the actual 7659 unit itself, I can assure you the tacho wire will be a yellow wire
