Author: Subject: c20xe to type-9 clutch
AndyGT
posted on 23/12/16 at 11:28 PM Reply With Quote
hi all,
Using above spec with sierra clutch (spinner disc) with xe pressure plate but just wanted to know which way round clutch disc should go before bolting it all together.... Daft question I know but better being safe than sorry!!
thanks for info and/or photos!!!
nothing is impossible
everything is possible
posted on 24/12/16 at 08:11 AM Reply With Quote
The clutch plate will probably be marked flywheel side?
swanntech
posted on 24/12/16 at 09:06 PM Reply With Quote
Clutch plate
Clutch plate in mine only fits one way if you put it the wrong way round the springs touch the flywheel
AndyGT
posted on 2/1/17 at 10:04 PM Reply With Quote
Yep! When I got home and tried fitting the disc it would only go one way!!! Doh... Stupid Question!!!
