Author: Subject: 3/8" UNF Bolts
Plunky
posted on 11/1/17 at 04:35 PM Reply With Quote
3/8" UNF Bolts
Replacing the shock absorbers and want to renew the bolts at the same time.
Looks like they are imperial as metric m10s are slightly too big.
Where can I get some bolts/nuts from? I need 100/70/60mm lengths or the nearest imperial equivalent.
Based near Portsmouth if anybody knows any local fastening shops?
Liam
gary gsx
posted on 11/1/17 at 04:59 PM Reply With Quote
Hi mate
I used a firm in Guildford bit out of the way but I believe they do mail order very very helpful and know there bolts they are called Margnor in Jacobs Well Guildford, Since moving down this way not really found any one else
Gary
ian locostzx9rc2
posted on 11/1/17 at 05:01 PM Reply With Quote
Namrick ltd in hove are very good used them a few times
joneh
posted on 11/1/17 at 05:07 PM Reply With Quote
Arun Fastener in Arundel. That's where I got all mine.
https://www.yell.com/biz/arun-fastener-co-ltd-arundel-808768/
perksy
posted on 11/1/17 at 05:57 PM Reply With Quote
iirc mine came from Namrick
Worth checking locally though at a decent engineering supplies company or similar and making sure sure they are the right spec
nilocp
posted on 13/1/17 at 04:46 PM Reply With Quote
I can probably supply.
How many do you need and what length? I have nyloc nuts and washers as well.
For future reference I carry quite a range of UNF and UNC fastenings
Colin
Plunky
posted on 13/1/17 at 04:52 PM Reply With Quote
Hi Colin,
All sorted now, thanks anyway.
I will keep you in mind for the future!
Colin
mark chandler
posted on 13/1/17 at 07:08 PM Reply With Quote
Although sorted now, favourite place would be an agricultural/farming machine repair shop if you want something immediately.
