Author: Subject: Do I need a Dashboard?
tajgreidotu
posted on 26/1/17 at 10:38 AM Reply With Quote
Planning my dashboard, bottom radious etc, and I wonder if to pass all the legal stuff is necessary to have a dashboard at all ?
I wonder if I am able to get all the necessary functions in the stalks, and with a motorbike dash....would that do the trick?
Thank you
ReMan
posted on 26/1/17 at 12:06 PM Reply With Quote
No NEED to have dashboard, there just a convenient place to place the glove box, dials and switches!
So as long as you mount the dials (probably behind the wheel, as long as you can see them ok) taking into account the sharp edges/radii /protrusions and soft faces I'd have thought you can do what you like
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
loggyboy
posted on 26/1/17 at 12:32 PM Reply With Quote
What would you have in place a big opening showing the chassis, wiring etc ? might be IVA-able but would look damn odd.
[Edited on 26-1-17 by loggyboy]
Mistral Motorsport
Ugg10
posted on 26/1/17 at 12:39 PM Reply With Quote
The Arial Atom seems to get away with it, different style of car but you get the idea.
and this MEV Exocet
[Edited on 26/1/17 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
jps
posted on 26/1/17 at 12:46 PM Reply With Quote
I assume they aren't passed under IVA though? I thought from previous discussions i've seen on here that some of what manufacturers 'get away with' under Type Approval - or whatever the small quantities production equivalent is - wouldn't necessarily get through IVA...?
tajgreidotu
posted on 26/1/17 at 01:52 PM Reply With Quote
Thank you for all you inputs!
My idea is to get the car registered and after that go carbon probably. Not that I like the format without dashboard, but if it takes me out the time to get one done just for IVA....
At the moment, this is what I have:
From your comments, I believe that might be less time consuming to make a temporary one that just to fix everything to and go dash-less route.
Javi
[Edited on 26/1/17 by tajgreidotu]
ReMan
posted on 26/1/17 at 02:36 PM Reply With Quote
As mentioned, unlike a screen say, which makes it easier to pass without the added complication, I would agree, that an ugly but well padded dash would look better than none and pass better!.
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
SteveWallace
posted on 27/1/17 at 10:35 AM Reply With Quote
Remember also that the dashboard protects everything behind it from radius testing, so it might be easier to put one on than make sure that everything that would have been behind it will pass IVA. You can always change it afterwards. I made mine with about £10 worth of bits from B& Q.
theduck
posted on 27/1/17 at 01:31 PM Reply With Quote
I agree with others, fitting something cheap and easy for IVA and changing after as the way do it, though cant see why you couldnt make a carbon dash to pass that also looks the part.
