Author: Subject: Using MX5 rear subframe complete
ludsonline
posted on 26/1/17 at 12:54 PM Reply With Quote
HI,
Why does no one use the MX5 rear subframe complete? I know it weighs a little more but would speed up the build no end
Ugg10
posted on 26/1/17 at 03:48 PM Reply With Quote
They do, look at the MEV vehicles - Exocet and Replicar - but they use the whole mx5 "chassis" including the front subframe and connecting framework.
But in a Seven type car they add a lot of weight for little return when you can do the same with a lot less 1" tube to replicate the mounting points plus you do not get the benefits of double wishbone suspension and would have to revert to the McPherson strut type suspension.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
ettore bugatti
posted on 26/1/17 at 08:15 PM Reply With Quote
Like the concept of the space frame Bauer Catfish is using:
http://nebula.wsimg.com/fed772661e14e1c94fbcf62e678ec306?AccessKeyId=F9677BCFCAD27219EACC&disposition=0&alloworigin=1
ludsonline
posted on 26/1/17 at 08:25 PM Reply With Quote
That's nice
