Author: Subject: ETB speedo on Mk2 gearbox speed sensor
Ianboom
posted on 24/2/17 at 02:51 PM Reply With Quote
Hi
Has anybody on here had a go at connecting up an ETB speedo to a Mk2 gearbox speed sensor?
ETB weren't a lot of help!
My plan is to get the car on axle stands and try to set it up, ideally, I could do with an oscilloscope to help.
Ian
Ugg10
posted on 24/2/17 at 03:03 PM Reply With Quote
was about to fit my digidash 2 to a type 9 (similar fitting I think).
Revotech do an adapter and then use a puma/fiesta/focus encoder. Encoder pattern and connections are -
Brown - ground, Yellow/Brown - signal, Black/brown - Live (12v/5v)
Signal is an equal square wave with (0-live feed amplitude) and 8 waves per rev.
Note the drive is geared to the output revs of the prop, so need to a bit of experimentation to work out the prop to encoder ratios.
ETB seemed to think that would work.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Ianboom
posted on 24/2/17 at 03:18 PM Reply With Quote
Hi
The MX5 sensor has a 2 wire output, I'm not sure whether it uses ground from the gearbox as I thinks it's a plastic unit.
I wish I'd had a play with it before I fitted the transmission covers (It's fitted to a Westfeild).
Ian
Ianboom
posted on 28/2/17 at 12:08 PM Reply With Quote
Done a bit of digging.
The MX5 gearbox output is a VR (variable reluctance) sensor which output a squashed sine wave.
I'm in the process of checking, but I think the ETB gauge requires a square wave.If so, I need a signal conditioner.
If this is the case, I reckon I can build one at work.
I'll post what I find.
Jed
posted on 28/2/17 at 07:04 PM Reply With Quote
The setup posted by Ugg10 is the same that I used on my Midget (4AGE plus type 9) with an ETB electronic speedo. Although the sensor can do 5 & 12v the speedo only worked with a 5v signal.
Ugg10
posted on 28/2/17 at 07:57 PM Reply With Quote
Sorry, my post was a bit misleading, when you said mk2 I naturally assumed escort not mx5.
Can you not use an etb pickup and use the two magnets on the prop/front or rear hub? Since moving from a type 9 to an rx8 I have converted to this.
Ianboom
posted on 5/3/17 at 08:25 PM Reply With Quote
Sorry!
Mk2 MX5.
I ended up putting one of the signal wires from the speed sensor to ground and the other to the brown wire on the gauge.
This seems to work, I just need to see if the gauge can handle the potential voltage from the sensor.
I had a signal conditioner made up at work, but couldn't get it working!
Leeroy06
posted on 5/7/20 at 07:56 AM Reply With Quote
Any progress on this? How did it work out? Im looking at running a digital speedo off the mk 2.5 gearbox sensor if i can.
Lphillips
Ianboom
posted on 5/7/20 at 11:31 AM Reply With Quote
Hi
That post was over 3 years ago.
It been working fine ever since!
Regards
Ian
