Author: Subject: Indicator Problem
Black Cat
posted on 10/3/17 at 09:44 PM Reply With Quote
Indicator Problem
Hi gents,
Have a problem with my indicator lights on my Tiger Avon. I have a Tiger supplied loom and I had a loose wire on the side indicator, which incidentally is LED as are the rear one but the front ones are normal bulbs. When playing around with the cables on the side indicator I must have touched the cable ends together and now the indicators won’t work. I’ve checked all the fuses and they are OK I’ve checked for loose connection and they all seem OK, and the relay hasn’t got a fuse in it so I’m assuming this is also OK.
It is only all the indicators which aren’t working.
I would appreciate any suggestions on what could be the problem.
posted on 10/3/17 at 10:03 PM Reply With Quote
Any chance you reversed the wiring when you were playing?
tbowdery
posted on 11/3/17 at 03:13 AM Reply With Quote
David makes a very valid suggestion.
I had the same problem last week and learned that as LEDs are a type of diode they will only allow current to flow in one direction.
As soon as I flipped the connections, everything worked just fine.
Hope that helps.
Regards,
Tony
Black Cat
posted on 11/3/17 at 07:44 AM Reply With Quote
I'll give it a go, but I did disconnect the LED indicator and I thought all the others should work. Think I will also test the relay.
snowy2
posted on 11/3/17 at 08:51 AM Reply With Quote
Led are light emitting diodes........current only flows oe way. However the idicator flasher relays used for led indicators are very fragile and will blow if wired incorrectly .
sometimes you are the pigeon, most of the time the statue.
Black Cat
posted on 13/3/17 at 12:30 PM Reply With Quote
Now checked the relays and they are all working. Also seem to have continuity from the indicator stalk to the lights but still no indicators working.
Any ideas of what could be the problem would be very much appreciated.
