<<  1    2  >>
New Topic New Reply
Author: Subject: Tiger HS6
BrumBrum
posted on 18/3/17 at 09:46 AM Reply With Quote
Tiger HS6
Well there are several kits on my list to view at the Stoneleigh Kit Car Show. Quite varied styles really. But one that I keep going back to and yet I haven't seen much information about is the Tiger HS6. I think it is absolutely gorgeous!
Tiger HS6 Front
Tiger HS6 Rear
Has anyone built one or do you own one? If yes what is your drivetrain? What is the quality of the kit like? Any info really that will give me some pointers/things to look out for before I go to Stoneleigh.
By the way high BHP isn't on my shopping list, more the character: )
Simon
Ugg10
posted on 18/3/17 at 10:31 AM Reply With Quote
If you like this then have a look at the batho alloy seven kits. http://bathoscars.simpl.com
I would keep it periodish with a xflow or maybe a Lancia/fiat 1600 twin cam or as the tiger site says a spitfire engine (1500?)..
This may also be of interest - spitfire based corsa spider https://www.corsaspyder.com/t48-details
Or the pembleton - http://www.pembleton.co.uk
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
BrumBrum
posted on 18/3/17 at 10:47 AM Reply With Quote
The Batho looks interesting and decent value for money. Is it basically a Haynes?
I'm not as taken by the Pembleton or T48, though I can see their appeal: )
ettore bugatti
posted on 19/3/17 at 03:53 PM Reply With Quote
Tiger has normally an extensive stand. IIRC they had the HS6 with them for the last couple of years.
BrumBrum
posted on 19/3/17 at 09:22 PM Reply With Quote
Good point. I might give Tiger a call. Martin at Batho says his MB1 will be on display. The perfect mix for me would be an aluminium HS6: )
Ugg10
posted on 19/3/17 at 11:14 PM Reply With Quote
Tiger did do an all alloy car but I think it was a version of the r6. Not cheap though.
[Edited on 19/3/17 by Ugg10]
softfeet
posted on 20/3/17 at 03:57 PM Reply With Quote
I don't think Tiger have an HS6 demonstrator at the moment, but they sometimes use completed customers cars to show to prospective customers.
One of their customers built one with GRP panels and has progressively replaced them with aluminium panels.
Engine choice is interesting. The Ford sidevalve would be authentic, but very slow. The Ford pre-crossflow would still be 'period' but more powerful. The Lotus Seven series 1 was offered with the BMC 'A' series. Tuning knowledge for these is extensive, but they can be expensive to make powerful.
Finally, how about a Coventry Climax engine? Fire pumps (using the FW engine, I believe) often appear on eBay. The can be converted to automotive use with a bit of ingenuity (and expense!) to effectively become an FWA.
http://http://www.ebay.co.uk/itm/Coventry-Climax-Engine-Godiva-Fire-Water-Pump-/282398511253?hash=item41c0435095:g:recAAOSwOgdYof6j
softfeet
posted on 20/3/17 at 03:58 PM Reply With Quote
Coventry Climax Engine Godiva Fire Water Pump
BrumBrum
posted on 21/3/17 at 07:51 AM Reply With Quote
Yes the RS6 and it does look very nice but as you say the price is quite expensive. The MB1 scores better in the pricing.
That is very interesting about the fire pump. I'm not sure I'd go that way as it is a period looking car I would really want to try and get an age(ish) related plate although I'm aware that there are many advantages to having a Q plate.
I'm guessing that probably the Spitfire route would be the easiest and cheapest way to go, if I did go for the HS6?
All food for thought: )
softfeet
posted on 21/3/17 at 11:26 AM Reply With Quote
You could build it with a Spitfire engine to get an age related plate and then put a Coventry Climax engine in later...
Here is a short film of a fire pump engine being converted to automotive use.
https://www.youtube.com/watch?v=YI8G0a2eWKo
ettore bugatti
posted on 21/3/17 at 05:40 PM Reply With Quote
Imp engine have been bolted to spitfire gearboxes before and is related to Climax.
BrumBrum
posted on 22/3/17 at 08:47 AM Reply With Quote
Apparently Tiger aren't producing HS6's at the moment.
alfas
posted on 22/3/17 at 11:05 AM Reply With Quote
i owned a HS6 for 3 years.....was factory built by tiger and one of their first demo cars. (came with 1050cc spitfire engine & gearbox, spit uprights front, VW steering, rear axle ford, converted to disc brakes with welded-on(!!) discs)
the car was extremely small inside. passenger side was for a slim 15 or 16y old...and the driver should be slim as well (jeans size 29-30inch)
BrumBrum
posted on 22/3/17 at 11:41 AM Reply With Quote
Uhmm... welded on discs, that sounds interesting.
How you describe the size it may well be too small for me. Size is one of the things I need to get my head round at Stoneleigh as there are several cars I fancy and it is whether or not I'll fit... 5' 11" 85Kg.
Other than the welded on discs and size, did you enjoy it?
alfas
posted on 22/3/17 at 01:28 PM Reply With Quote
the car was fun to drive....dont expect a rocket with an old spitfire engine...overdrive gearbox was a great advantage.
it also was a viewers-"magnet" on every meeting.
i later converted the car to a slightly tuned 1300cc engine.
anyway:
the original engine and box where leaking oil like hell, the gearlever was moved further backwards by using 2 triumph gearbox extensions, cut in the middle and botched togehter with some fibreglass.(!!)
the engine was positioned in the enginebay that the front carb could not be run with any trumpet nor any airfilter.
no trumpets on SU carbs, that doesnt work. luckily i found some quite short trumpets which i modified. during engine change i could slightly re-postion the engine without touching the mounts.
the boot compartment was OSB wood which was cut out using the 3rd teeth of somebodies grandma, than covered with a carpet which was cut by a dull scissor.
the rear springs/shocks had the wrong length as rebound was limited by a chassis-member.
welded brake discs
so some interesting "masterpieces" of engineering.
the chassis is , imo, wrongly desinged in terms of inside space and width of propshaft-tunnel area of chassis.
i am 172cm and around 70kg and it was a snug fit.
[Edited on 22/3/17 by alfas]
BrumBrum
posted on 22/3/17 at 03:35 PM Reply With Quote
anyway:
welded brake discs
Thanks for a bit of insight, sounds like quite an interesting experience! Perhaps I won't go for one of their builds!
I can understand the HS6 being a popular car on the meetings and that's the bit of me that wants people to enquire what car it is... I've always enjoyed boring the pants off people
striker1660
posted on 22/3/17 at 09:02 PM Reply With Quote
Simon, i went through this process. The seating is very narrow even when they revised the chassis and got another 1" wider. It seems Tiger doesn't wan't to change anything. i actually couldn't sit in the seat unfortunately. i did go out with the the guy local to tiger and it was great if you fit in.
BrumBrum
posted on 23/3/17 at 06:38 AM Reply With Quote
It seems that so many of the cars that try to have a hint of history about them are on the small side and unfortunately it is that small, lightweight look that I like. I can appreciate the looks of something like a cobra (which wouldn't be a problem size wise) but it just isn't me, having said that maybe a 289 would work.
I think Stoneleigh is going to be a bit of a Cinderella story... keep trying until I find something I like and fits (oh and I can afford).
alfas
posted on 23/3/17 at 11:11 AM Reply With Quote
if you want somethign "retro" a MEV Replicar might be interesting? (even, imo, the proportions of that car arent correct)
or do you prefer more the seven-ish style cars?
also interesting an Auston Healy remake based on a locost:
Healey body conversion kit Locost 7 To Build Kit Car ,Indy ,Caterham , Westfield
Toys2
posted on 23/3/17 at 11:25 AM Reply With Quote
How about a Lotus 23 replica if you want something different?
I've got a part built Auriga 23 which is a Lee Noble design, I plan to get round to it....sometime
I see Tiger have listed one on ebay
NEW TIGER ERA 30 - HISTORIC LOTUS 23B TRIBUTE - KIT CAR - FINANCE- NO RESERVE!
I always thought that Tiger were a good company, though I have read some negative comments about poor quality and customer care??
BrumBrum
posted on 23/3/17 at 12:04 PM Reply With Quote
I've not seen the MEV Replicar before, looks nice at first glance... one more to add to the list to look at.
Austin Healey replicas are a no for me as a mate is on restoring his second 3000, just wouldn't feel right: )
I do like the Lotus 23's and have seen the one on ebay but it is probably just bad timing for me as I'll do Stoneleigh before I start rushing in bidding.
How come you haven't got around to building the Auriga 23 yet? What power are you going to use for it?
BrumBrum
posted on 23/3/17 at 12:30 PM Reply With Quote
Just spent a few minutes looking at the MEV Replicar and you are right the proportions are wrong but as a nod to the DBR1 it does have something about it. I do like the fact that it isn't just a rebody but utilises a lot of the donor car.
Definitely food for thought.
TimC
posted on 23/3/17 at 01:11 PM Reply With Quote
HS6 would be my next build - but would have bespoke IRS and a 3-pot Toyota, possibly with TTS SC. But I'll never build another.
If you want retro, have you thought about a Gemini?
Toys2
posted on 23/3/17 at 03:18 PM Reply With Quote
I bought it something like 15 years ago, it's one of my dream cars and it was an opportunity that I couldn't miss. I bought it from an ex Auriga employee
The normal thing though, work, kids and all the other stuff got in the way
I changed jobs 3 years ago and have a bit more free time (less money though) bought a cheap, running Sylva Striker as a well deserved toy, with the plan to get on with the 23 as time permits
It's now actually stored upright against the garage wall whilst I do some jobs on the Striker
At the moment the chassis is paneled, the steering, front suspension and wheels are on, it looks like an expensive wheel barrow!!!
I have all of the main bits, the rear uprights are a work of art in cast alloy. I have the bodywork and even the perspex aero screens (as per the Tiger picture)
Basically it's brand new, no donor parts other than an Alfa Romeo transaxle, so my plan is to go for a new registration using a new Zetec engine
The original used either the Coventry Climax or the Lotus Twin Cam, so I think a Zetec with a replica cam cover would look very good
Something like this, though with "Lotus" of course
BrumBrum
posted on 23/3/17 at 09:20 PM Reply With Quote
Toy's you are very lucky lad Sylva Striker and a Lotus 23 to play with!
So you've got more time than you used to have, the weather is improving and you've got the main bits... I'm looking forward to seeing it!
<<  1    2  >>
New Topic New Reply
