Author: Subject: Sierra Stalks with cable connectors
wowblaauw
posted on 27/3/17 at 07:50 AM Reply With Quote
All,
My quest continues. This time its more serious. Having purchased a P&P loom from GBS and converting the stalk switchgear to toggles, I have come up against an (for me) insurmountable issue. My belief is the loom has a fault, but as GBS advise all looms are tested ahead of shipping which I do not doubt. Any how to prove a point I am in the hunt for a set of sierra stalks with cabling for both sides - any help would be gratefully received and prevent my sanity from leaving.
Thanks again
Craig
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming...
Damn, What a ride!!"
Dingz
posted on 27/3/17 at 08:00 AM Reply With Quote
There are 2 types of Sierra stalks, the early ones have a square hazard switch the later has a round one. The wiring is different, early ones didn't use headlight relays either.
went on and on.
big_wasa
posted on 27/3/17 at 12:15 PM Reply With Quote
I remember three types. Two later types that had different wiring and the early type.
wowblaauw
posted on 4/4/17 at 09:38 PM Reply With Quote
Basically I wanted these to test a loom for my 7. I have now sorted the issue with the loom so no longer require the stalks.
I would like to say a big thank you to those who responded in my hour of need.
Craig
