Author: Subject: Duratec flywheel help
ibakes
posted on 28/3/17 at 09:16 AM Reply With Quote
Hi All
I Have just purchased the following flywheel for my Duratec
The gent I bought it from was great and answered all of my questions before I siad yes to it.
However it was delivered yesterday and have 2 issues.
1. The standard clutch kit does not fit, bit of a shame but with no real details on the flywheel, how do I find out what will fit?
2. When fitted, it sits so close to the block that the starter motor will always be engaged (overlapping by around 5mm I think), the person who sent it out to me mentioned a spacer (or just washers), has anyone else had this issue? or know of anyone who sells the spacer?
Many thanks in advance.
Dick
posted on 28/3/17 at 09:57 AM Reply With Quote
The person that sent it mention using washers and you still want to fit it
ibakes
posted on 28/3/17 at 10:12 AM Reply With Quote
yeah, its kindof why I am asking about the spacer/shim or if anyone else has had this issue or where to get one from?
the gent i got this from never fitted this to his car as he was able to get a full kit from a friend.
or is there anyway i can correctly identify what this would have been from?
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 28/3/17 at 12:03 PM Reply With Quote
Where are the threaded holes for the clutch cover to bolt to. Are you sure bit's not a stator plate for an automatic........
ibakes
posted on 28/3/17 at 12:25 PM Reply With Quote
this is the other side
[img]https://goo.gl/photos/hf4v2oV5bodX6Neb7[/img]
the standard clutch and plate do not allign to the locator holes. I can take the flywheel along to euro's and get them to find one that fits. but its mostly the spacer plate that rings alarm bells, I have found spacers but not sure they are meant to fit between the block and the flywheel.
strator plate???
se7ensport
posted on 28/3/17 at 03:14 PM Reply With Quote
It looks like the Titan one Burtons sell: http://www.burtonpower.com/steel-flywheel-184mm-clutch-rwd-lightweight-fd252.html
Its designed to take a 7.25" competition racing clutch.
The starter motor gear on a Duratec is always engaged with the flywheel, it does not "shoot out" to engage i.e. older style.
Shouldn't need any spacers or washers, just a set of ARP flywheel bolts with loctite 242 (hard to find, got mine from ebay) and ARP assembly lube (comes with the bolts).
ibakes
posted on 28/3/17 at 03:31 PM Reply With Quote
Many thanks
That looks quite different to my pictures
The standard clutch fits the main 'ring' and the plate is very close to fitting but will only go over one location pin at any time, however i will measure it all when I get home later on
I dont believe the dual mass flywheel and standard starter are overlapping in normal use, however will check later on too.
se7ensport
posted on 28/3/17 at 03:58 PM Reply With Quote
I take back the Titan comment now I've had a proper look on a laptop.
It unusual compared to other pictures of duratec flywheels in that it has raised lugs to hold the clutch assembly, only thing similar is from Dunnell for the Zetec:
Zetec Flywheel
ibakes
posted on 28/3/17 at 04:17 PM Reply With Quote
Yeah found simular on american websites but for other cars
evo one
i'll check the standard flywheel later against the starter but i am sure the 2 are not normally engaged
just found this.. probably the closest so far just missing the logs
CC flywheel
[Edited on 28/3/17 by ibakes]
ibakes
posted on 28/3/17 at 04:28 PM Reply With Quote
right think THIS IS THE ONE
guessing there is a lot different between a US 2013 Focus and 2005 Mondeo
se7ensport
posted on 28/3/17 at 07:55 PM Reply With Quote
The newer focus ST uses an ecoboost, not a duratec.
https://en.m.wikipedia.org/wiki/Ford_Focus_(third_generation)
ibakes
posted on 29/3/17 at 08:04 AM Reply With Quote
pants
least i know roughly what clutch to look for
back to the spacer question.. anyone ever heard or used one?
i can get one made up but still not sure i want to use one giving the speed the go
