Author: Subject: Tiger Avon part built project
locost7-online.com
posted on 11/5/17 at 06:00 PM Reply With Quote
Tiger Avon professional fabricated chassis painted zinc rich undercoat and black rustolem paint fitted with alloy floor, back panel, scuttle, side panels, I used lasers to make sure the chassis was aligned
Floor mounted pedal box
22 x 44mm wishbone brackets
33.7 x 2.6 shs 6.0 mtr poly bush tubes
26.9 x 2.5 mm tube chs rear wishbones
List of parts used
Cortina uprights reconditioned fitted with new wheel bearings, discs, brake calliper overhaul kits, not fitted yet
3.62:1 sierra diff unit, revealed and cleaned
Lower steering joint
Poly bushes full set duraflex
lower balljoints fiat 124 x 2
Sequential gear lever
Camber adjusters, front upper wishbones
top ball joint m18 transit drag links
Top seat belt anchors, 50mm long, 20mm diameter , 7/16 thread
7/16 unf nuts for side seat belt mountings
Non slip 3M tape for pedals
Coolant radiator VW Polo 2002>
Shock absorber brackets 34mm x6
Sierra handbrake lever
Rear uprights
Fireblade 893 engine complete with loom and ancillaries
Pit bike steel gear lever
Sierra steering column with wheel and cowl
Red body tub, bonnet, nose and bootlid has marks and scratches on it ( mostly from factory)
steering shaft extended 60 mm
Sierra steering column bush
Fire blade exhaust and manifold stainless
Gear linkages rods and ends
Electric Reverse set
Drive shafts, hubs and flanges
Rear drum brakes with new shoes and cylinders
Vin plate weld on
rubber mounts for radiator
Fiat 124 dual master cylinder
brake fluid resovoir iva compatitive
brake pipe clips X 30
14 circuit wiring loom from branshatch
25x25 plastic bungs x15
50x 25 mm plastic bungs x2
Brake compensator valve m10x1
M12 X 200 bolts with nyloc nuts for differential
M10 X11.25 male brake fittings for master cylinder x5
5mm black p clips for brake pipe
Seal kit for Sierra diff
m12x140 bolt with nyloc I x2 for bottom of rear hub
8mm lines metal p clips x25 for fuel line
Powder coat front suspension wide track
Golf mk 1 handbrake cables pair
8mm bore copper fuel pipe and olives
Rear wheel cylinders pair
Rear wheel bearing
Rear wheel bearing
2.9 turn mk2 Escort quick rack 14mm ends with alloy raldes brackets
Tiger Heat sheild for exhaust
10mm p clips
Driveshaft boots x 4
Steering rack extensions
Steering arm m14 nuts
63mm wheel studs x 16
Goodrich hose 2 mtr
40x4 m12 washers for rear suspension
M8x1.25 Clevis with 8mm hole for master cylinder
I have used all new parts where I can, otherwise all the rest is reconditioned
Please look at the pictures
I'm looking for £2500 for everything, as I now have problems with my knees I am unable to complete
Anything you want to know please ask.
Can't get the photos on here but can email them as required
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
rayward
posted on 11/5/17 at 08:30 PM Reply With Quote
u2u sent
cheers
locost7-online.com
posted on 14/5/17 at 07:51 AM Reply With Quote
Weekend bump
daz500
posted on 18/5/17 at 08:15 PM Reply With Quote
sent an email asking about this.
locost7-online.com
posted on 15/8/17 at 05:44 PM Reply With Quote
Dropped price to 2000 for everything I have, Facebook link is working again so all the pics are on there
If it doesn't go in one go I will break it up
Bargain!
[Edited on 15/8/17 by locost7-online.com]
Smiithyy
posted on 15/8/17 at 06:25 PM Reply With Quote
Interested mate will contact u via Facebook
One day!
posted on 16/8/17 at 04:47 PM Reply With Quote
Your car
Hello,
Could I ask if This is still for sale as I'm interested.
locost7-online.com
posted on 22/8/17 at 07:27 PM Reply With Quote
Now sold, thanks for your interest.
