Author: Subject: Lucas bulb holder connection - help please
TimC
posted on 20/5/17 at 07:08 AM Reply With Quote
Hi All,
I'm a bit baffled by something. I'm using Lucas 488-type rear lamps on my car.
Bulb Holder
Bulb Holder
I can't work out how to properly connect wires to them. The positive connections look straightforward in that I expected 4.7mm Lucas bullets to just clip in, but in more than half of the cases the ring-receptical is too big for the bullet.
The earth connection is even more puzzling. I could put a rivet in it I suppose but I guess there is a proper method?
TIA
theconrodkid
posted on 20/5/17 at 07:20 AM Reply With Quote
proper old skool them be,brass solder on bullets were used,if it is a bit loose,give the female bit a squeeze
who cares who wins
pass the pork pies
Camber Dave
posted on 20/5/17 at 07:25 AM Reply With Quote
Hi Tim
Brings back Memories
We used a brass, hollow ferrule with a flange on one end and a small hole in the other.
The cable was stripped back about 10 mm an pushed through the ferrule and the stripped portion folded back
Then when it was pushed into the lamp the rolled tab gripped the ferrule and cable
Dave
Had a search but can't find any
But these will do if you crimp the rings a bit
http://www.vehicle-wiring-products.eu/product.php/453/w-crimp-type-4-7mm-bullet
[Edited on 20/5/17 by Camber Dave]
TimC
posted on 20/5/17 at 12:18 PM Reply With Quote
Originally posted by Camber Dave
Hi Tim
Dave
Gosh - this sounds a bit haphazard. No wonder classic electrics are problematic. I'll go for ring connectors riveted I think.
Also, Dave - am still planning to bring car over for 'finishing' but am about to move house so I'm saving pennies.
Thanks,
Tim
posted on 20/5/17 at 07:58 PM Reply With Quote
Use the proper connectors with silicone grease don't try anything else.
snowy2
posted on 21/5/17 at 06:46 AM Reply With Quote
you could of course just fit different lights.....
sometimes you are the pigeon, most of the time the statue.
