Author: Subject: Mx5 crank position sensor and Omex 600 ecu
APR
posted on 29/5/17 at 09:49 PM Reply With Quote
Does anyone know which cables are what colour on the Mx5 crank position sensor I.e. +12v , signal and earth and what colours they go to on the Omex 600.
Ta
ash_hammond
posted on 30/5/17 at 12:38 PM Reply With Quote
If its an early 1600, it does not have a crank position sensor. It just has the can sensor.
.: www.mac1motorsports.co.uk | www.m1moc.com :.
APR
posted on 30/5/17 at 01:28 PM Reply With Quote
2001 1.8 bodies engine - definitely one there 😃
ste
posted on 30/5/17 at 05:51 PM Reply With Quote
+12v ~ white/red trace
signal ~ grey/red trace
ground ~ black / blue trace
cam shaft is the same but signal is grey/blue
I have the full wiring diagrams if you u2u me your email address i'll send them to you
[Edited on 30/5/17 by ste]
ste
posted on 30/5/17 at 07:51 PM Reply With Quote
I'll email them over when I'm back in the house
APR
posted on 30/5/17 at 07:55 PM Reply With Quote
This is the Crank sensor connector and wire colours
ste
posted on 30/5/17 at 08:08 PM Reply With Quote
mines the same colours as yours and not the diagram!!
everything else ive ever checked has matched so not sure what's going on there.
I'd use the positions as shown in the diagrams i sent though. page Z20
the drawings are looking into the back of the connector, not the plug for the sensor. You can find the ground easy enough with a resistance check, and 12v will also be easy. then confirm with the drawings
[Edited on 31/5/17 by ste]
APR
posted on 30/5/17 at 09:38 PM Reply With Quote
I've been searching the web and trying to test my sensor but it looks like I need a 1K resister between the +12v and signal cable !!
Not sure if this is correct but i will give it a try
APR
posted on 1/6/17 at 05:08 PM Reply With Quote
All sorted
Mx5 crank sensor is a hall type and the wires are Red +12v, Blue - Signal and Black - Gnd
