Author: Subject: Maxi Ball Joint
the_big_1
posted on 30/5/17 at 12:16 PM Reply With Quote
Maxi Ball Joint
Hi All,
does anyone have the part numbers, QH numbers etc, for the maxi ball joint on a Haynes Roadster?
I need just one.
[Edited on 30/5/17 by the_big_1]
rash12
posted on 30/5/17 at 01:02 PM Reply With Quote
AUSTIN MAXI Ball Joint QSJ602S Quinton Hazell BTA946 New
Brand Quinton Hazell
Part Number QSJ602S
Placement on Vehicle Lower Front Upper Front
Cone Size 16mm
Number Of Bores 2
OEM references
ROVER BTA 946 BTA946
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 30/5/17 at 06:23 PM Reply With Quote
http://www.mksportscars.com/bottom-ball-joint-maxi-mk-indy-bottom-ball-joint.html
