Author: Subject: Supercharged MK Indy R, ultimate track/fast road car
Bigbaddom
posted on 13/6/17 at 05:43 AM Reply With Quote
Photos to follow when I can figure out how to upload them! Car also on EBay, item number 132224290670.
After much deliberation and soul searching, here we have for sale my pride and joy, my MK Indy R which weighed 535kg at IVA. This car has been pampered! Total investment to date is in excess of £25,000.00. The car is stored in a heated, air conditioned garage to ensure it is kept in the best conditions.
The chassis is the Mk Indy R chassis with optional full roll cage fitted from new by the manufacturer. Finished in black gel coated bodywork with GSXR decals and extensive genuine carbon fibre additions. First registered in 2010, the car has covered less than 8000 miles and has been serviced and cared for religiously. There is an 11 month MOT remaining, which runs out on 23rd May 2018.
A TTS Performance Rotrax Supercharger installation was professionally installed in November 2015, boosting power to 223.29hp at the wheels, which equates to around 260bhp at the crank. Torque is also up substantially from 62.96 to 98.54 ft lbs. Remember this car weighs 535kg, so power to weight ratio is around 486bhp/tonne. That’s the same as a Lamborghini Aventador!
In addition the 2005 GSXR 1000 K5 engine benefits from the following spec:
• Baffle plate with swinging pick up and wet sump (billet sump) with oil cooler
• Handmade TTS plenum chamber, intercooler and oil cooler
• Klicktronic gear shifter activated using buttons
• Trick Shifter this is linked to the Klicktronic so does full throttle up shifts
• GSXR 1000 K5 clocks with gear shift indicator & Reedy boost/voltage gauge
• 4 branch stainless manifold
• Akrapovic carbon tri oval exhaust 102db
• Power Commander 3
• Candy red powdercoated rocker cover/clutch cover & stator cover
• Aluminium header tank powder-coated graphite grey
• All black silicone hoses
• GSXR billet pair covers on cam cover
• New stator, stator rotor and regulator
Further spec/information on the car is detailed below:
Brakes/wheels:
• FRONT: Hi Spec 4 pot calipers, 325 mm drilled discs with aluminium bells
• REAR - Hi spec 2 pot calipers, 275mm drilled disc
* EBC brake pads all round
• Braided lines all round • 5.1 brake fluid
* Brakes alone cost £1500
Carbon parts:
• Carbon Mods front canards on nose cone
• Westfield carbon aero screen
• Carbon Mods air duct on front nose cone
• MK carbon dashboard
• Carbon covers side where your elbows go
• Carbon arch protectors
Other details:
• Front and rear adjustable MK anti-roll bar kit installed, all powdercoated Candy Red to match
• Full suspension set up by Gotboost Ltd (professional race car engineers)
• LSD 3.62 rear diff
• Candy Red powdercoated front and rear hubs to match
• Quick rack 2.2 turns full lock
• Quick release wheel hub
• Team Dynamics 4x 17" Pro 1.2 alloys with Avon road legal cut slick tyres, ideal for fast road and track use (super light wheels)
• MK front splitter with aluminium supports
• MNR rear diffuser
• Carbon wrapped steering arm
• Black aluminium flush fitted fuel filler cap
• Quality discrete supercharger badging
Interior:
• Momo flat bottom steering wheel, with quick release, electronic buttons on steering wheel for gear change
• Corbeau Le Pro seats x2 (£945 not including runners, the same as in a Lotus Exige)
• Carbon dash with GSXR clock and Reedy boost gauge
• Savage switches lights/ hazards/ handbrake light/rear fog light - 12 switches that illuminate blue while driving
• Carbon panel in front of handbrake with start button indicators horn and reverse
• GSXR keyswitch
• Thatcham Category 2 immobiliser
• Momo handbrake lever
• Aluminium bespoke centre console covered in very light black carpet
• OMP passenger foot rest
• Black 3” TRS 4 point harnesses
• Bespoke rear boot with carriage access fully carpeted
• Race gel battery and cage
• Longacre centre mirror
• Caterham side mirrors
LED Lights:
• Clear rear lights include: brakes, indicators, reverse and fog light all clear LED with carbon outer cases
• Front headlights have had a full hid bulb conversion
• Front led indicators
As you can see, the spec is extensive with no expense spared. This car is brutally quick and makes an ideal track car, although she is fully road legal and I do in fact use her on the road more often than anything else. At the same time, she has been built with some comfort in mind, for example, instead of lightweight hard seats, she has supremely comfortable and expensive Corbeau Le Pro seats installed.
I am the second owner from new, having owned the car for 3 years. The original owner and builder is a mechanical engineer and his kit car builds are well known and respected in the industry, with this car and his current car having featured in kit car magazines and been on manufacturer’s stands at shows.
Extensive paperwork is included in the sale to maintain the history of the car. £16995 or near offer.
[Edited on 13/6/17 by Bigbaddom]
McLannahan
posted on 13/6/17 at 09:56 AM Reply With Quote
[Edited on 13/6/17 by McLannahan]
Bigbaddom
posted on 13/6/17 at 10:03 AM Reply With Quote
Not sure how you did that, but thank you so much for getting the photos over onto this post!
