Author: Subject: Wiring loom weight ?
froggy
posted on 17/6/17 at 12:35 PM Reply With Quote
Anyone sad enough to weigh the car side loom on their kit ? Used a painless kit last time and with the battery cable it's 7.5kg and lots of it is now redundant for the new engine going from turbo mid layout to n/a front engined so lots of weight coming out and I'm going to monitor the weight as it's re built . tia
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
steve m
posted on 17/6/17 at 03:53 PM Reply With Quote
No im not that bloody sad
but I did weigh all the crap I took out of the loom, and other redundant bits in the car, 5.2 kg it was,
and another saving of 13kgs changing the wheels and tyres
Hasn't seemed to of done anything to the performance, but if I removed all the "spares" in the boot, that should save another 10kgs
froggy
posted on 17/6/17 at 08:37 PM Reply With Quote
The loom I've taken out of the car weighs 7.3 kg with fuse boxes and battery cable which seems a lot but it's an American kit so all the wire gauges are a bit much for what they're Doing
snowy2
posted on 18/6/17 at 06:20 AM Reply With Quote
I make my own looms for my cars even rewiring the ford Zetec ECU stripping out and getting rid of all the non used stuff. i would be amazed if it was more than 1 kg for the wiring only need to add on a car battery (dont need a big battery)
sometimes you are the pigeon, most of the time the statue.
b14wrc
posted on 19/6/17 at 11:15 AM Reply With Quote
Fiat Coupe 20V Turbo Loom weighs a tonne!
Hopefully I will be able to scrap off a load when I get to that stage.
Rob
20vt powered rear engined locost
Huttojb
posted on 23/6/17 at 10:24 AM Reply With Quote
I've done the same, I am re-wiring my car and saving all the wires I take out to finally weigh.. I have adopted to go to CANbus allowing minimal wiring to be used up and down the tunnel.
Saying that.... If I went on a diet, I'm sure that would be more then enough, as I am probably the heaviest thing in the car lol.
jason
Jason
huttojb_GenTiger
huttojb_GenTiger
There are only 10 types of people in the world. Those that understand binary and those that don’t.
If only DEAD people understand hexadecimal - 57,005
WesBrooks
posted on 18/7/17 at 06:47 AM Reply With Quote
I've two binbags worth of wiring that came off the '95 discovery! Probably the worst age for wiring as CANBUS and distributed electronics hadn't really been taken up by Land Rover. My replacement loom has different priorities to you guys though and the 1000A bus bar soon puts weight saving ideas to bed!
http://doctrucker.wordpress.com
Mr Whippy
posted on 18/7/17 at 01:31 PM Reply With Quote
I mind my old Volvo 850 had about 45 wires running from front to back! scary electrics fortunately very well made so reliable would have been really heavy
for simple cars like old classics, landys and 7's especially those running LED lights, lightweight trailer cable works very well and has all the wires for the back of the car. Just run it right into the instrument panel.
