Author: Subject: Using VFD's with single phase motors
liam.mccaffrey
posted on 8/7/17 at 10:30 PM Reply With Quote
Does anyone have any experience using VFD's as speed control on single phase motors.
I have a 1.1kw single phase motor which I need to be able to alter the speed of.
Thanks in advance
Liam Mc
Build Blog
Build Photo Album
Toys2
posted on 9/7/17 at 09:23 AM Reply With Quote
Thanks in advance
Liam Mc
Unfortunately, You can't use a VSD with single phase motor, the option there is to swap the motor for a 3 phase 220V and then use an invertor with that
posted on 9/7/17 at 05:10 PM Reply With Quote
Single phase VFDs are definitely available, though single phase motors have significant disadvantages over three phase so there would need to be a compelling reason not to fit a 3 phase motor and VFD.
SteveWalker
posted on 9/7/17 at 05:35 PM Reply With Quote
Sell the single phase motor and buy a three phase one? At that power you could run the VFD from a single phase supply still.
Alternatively, but physically more complicated, a variable speed pulley system - Variable speed pulley system
liam.mccaffrey
posted on 9/7/17 at 06:36 PM Reply With Quote
Anyone want to buy a brand new 1.1kw single phase motor
Build Blog
Build Photo Album
Toys2
posted on 10/7/17 at 10:13 PM Reply With Quote
Yes there are single phase VSD's but they drive 3 phase motors. As far as I know, it's not possible to control a single phase motor due to the requirement of phase angle generated by the capacitor start
coyoteboy
posted on 11/7/17 at 12:27 PM Reply With Quote
Single phase induction motor requires a cap to start to give a temporary phase difference between the two fields.
It will run at the speed given by the feed frequency.
You could attempt to run a single phase motor from a 3 phase VFD (just using one phase output) but it's a total kludge and might trip out the (unevenly loaded) VFD.
posted on 19/7/17 at 12:54 PM Reply With Quote
As I said it' most definitely is possible, and they are available. I suspect a capacitor start motor would not be suitable, or at least would limit the available speed adjustment at startup, but a shaded pole or split capacitor motor would be ok.
http://www.invertekdrives.com/variable-speed-drives/optidrive-e2-single-phase/
https://www.wolfautomation.com/blog/vfds-for-single-phase-motors/
