Author: Subject: Welding T45 to Mild
posted on 20/7/17 at 08:04 PM Reply With Quote
Welding T45 to Mild
Evenin' all.
Anyone have any hints and tips for welding T45 tube legs to mild steel feet?
It's Evolution Baby!
r1_pete
posted on 20/7/17 at 09:26 PM Reply With Quote
309L rods should do you fine, assuming you're using TIG..
Neville Jones
posted on 21/7/17 at 10:54 AM Reply With Quote
HI Scott,
This is very similar to the alloy spec of the tube I used to use.
You can weld it using ordinary mig wire, providing you get a good fillet in the joint. No special alloy wires needed.
Tig with a special rod will be belt and braces, but a bit OTT.
nev.
Still got that big slobbering dog?
Slimy38
posted on 21/7/17 at 02:27 PM Reply With Quote
I've bought myself a roll of 308 MIG welding wire to have a go at some stainless welding. Problem is I'm only using a standard MIG welding gas so it's not going to look pretty.
I need to try stainless to stainless, then stainless to mild. This is for an exhaust so main thing is strong and airtight. Pretty doesn't matter.
posted on 21/7/17 at 03:26 PM Reply With Quote
Cheers guys!
Yes - the monster mutt is still with us Nev. Snoring away at my side as I type.
