New Topic New Reply
Author: Subject: Chassis Refurb
Ron Lang
posted on 1/8/17 at 05:49 PM Reply With Quote
Chassis Refurb
Does anyone have a view on reconditioning an existing chassis. I have access to a zero chassis (powder coated) which has never been used but has been built up. The builder was a little overexcited with the drill in my opinion and I am thinking of having all the holes welded back up and repowdercoated (at the same time as having a lowered floor put in). The powder coat is also quite scratched in places so would benefit from a new coat. Would this be worth it or would you just scrap it and by a new chassis? Seems like an awful waste of material seeing as the chassis is straight and true.
CosKev3
posted on 1/8/17 at 06:00 PM Reply With Quote
All depends how cheap the chassis is!
If you can buy it,get the holes welded up and re-powdercoat for a good saving compared to a new chassis then it's worth while
Ron Lang
posted on 1/8/17 at 06:02 PM Reply With Quote
I'm unsure how much a new chassis is tbh.
CosKev3
posted on 1/8/17 at 06:06 PM Reply With Quote
Drop GBS a email and find out
Fatgadget
posted on 1/8/17 at 09:25 PM Reply With Quote
How about posting some pictures!
alfas
posted on 1/8/17 at 09:41 PM Reply With Quote
complete starter kit costs 2345,-
http://www.greatbritishsportscars.co.uk/wp-content/uploads/2013/04/GBS_Zero_Ford.pdf
so the chassis might have a vlaue of 1000,- in the kit?
Tiger is asking around 850,- for the raw avon-chassis
MK around 1350,-
so not worth doing any effort on a 2nd hand chassis, especially as i would not trust a re-welded, formerly perforated, chassis.
loggyboy
posted on 2/8/17 at 12:14 AM Reply With Quote
Expand on your 'over excited with the drill' observation. Most chassis' get extensively drilled for panel rivets. These in turn reinforce the chassis by filling the gaps with rigid panels. Consider each river as triangulation. How bad is it really?
Mistral Motorsport
Ron Lang
posted on 2/8/17 at 06:26 AM Reply With Quote
Yes, mainly rivets for panels but I'd want to bond on the new panels so these would be left unfilled. There are also some rivnut holes which have been drilled in the wrong place for bonnet pins. I'm leaning towards building up an Indy now...if I could ever work out what's included in each of the kits they sell! Will have to make a trip down I think.
40inches
posted on 2/8/17 at 07:46 AM Reply With Quote
As loggyboy said, if you are bonding on panels, the Sikaflex will fill any unused holes and the panels will add strength.
And GBS are not that far from you
posted on 2/8/17 at 09:37 AM Reply With Quote
I'd have thought a new chassis would be a better option.
Surely resurrecting the old chassis will involve blasting off the powder coat, welding all the holes up (possibility of introducing heat distortion), blasting it clean again and then re-powder coating. Transporting the chassis around during this process will introduce further effort and potentially costs.
filstu
posted on 2/8/17 at 07:12 PM Reply With Quote
If your bonding on the panels, you wont need to drill any additional holes. therefore there would be no reduction in strength as you would have the same holes you would have had anyway.
ReMan
posted on 3/8/17 at 07:21 PM Reply With Quote
I'd just rattle can over it if its still sound Jd much cheapness
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
Ron Lang
posted on 28/8/17 at 07:56 AM Reply With Quote
Wanted to respond to this now I've stripped down a little more. Couple of examples:
Chassis Damage 2
Chassis Damage 2
Chassis Damage
Chassis Damage
Ron Lang
posted on 30/8/17 at 07:51 PM Reply With Quote
I'm waiting with bated breath for someone to answer the "how bad is it really"...
sebastiaan
posted on 30/8/17 at 07:56 PM Reply With Quote
That is repairable, but in steel almost anything is. If you can (learn how to) do the welding yourself, go for it. And 1k, that's 4 completed cars, right? ;-)
Ron Lang
posted on 30/8/17 at 07:58 PM Reply With Quote
Ha! So we're led to believe!
ianhurley20
posted on 30/8/17 at 09:44 PM Reply With Quote
IF - it is straight and true - AND - you can weld it up yourself then that is what I would do. As a friend of mine who rebuilds cars said - 'It's only metal' I do not like powder coat as you often want to add a bracket or change something on a sevenesque chassis as you develop the car and I think a decent paint job is better, easier to remove to weld, and easier to repaint.
And if you want to bin the chassis - let me know - I would fix it for myself
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why!
Ron Lang
posted on 30/8/17 at 09:55 PM Reply With Quote
I certainly can't fix myself unfortunately as I can't weld - I will learn one day!
I think I'll be selling it but I have no idea what it's worth or how many parts to leave on it.
ianhurley20
posted on 31/8/17 at 07:30 AM Reply With Quote
Perhaps now is the time to learn. get a mig welder, a bottle of hobbyweld gas (little ones are too expensive) watch a few videos on the web, practice on some scrap and have a go. Fill the small holes first then progress. You will surprise yourself, its not that difficult and you will learn how to weld properly by the end. If you are not happy with the result then sell it!
Oh - if you decide to sell I'll give you 20 and collect
[Edited on 31/8/17 by ianhurley20]
written off 23/9/18
Ron Lang
posted on 31/8/17 at 12:07 PM Reply With Quote
I think you're probably right on now being the time to try but unfortunately with work, two kids and a PhD to finish on the side, I'm forced into an assembly only role lol...although I have spent most of my time disassembling of late!
One of the questions I have outstanding is what would I do about the powdercoating. Once I had [theoretically] welded up all the holes, would I just paint over these bits...with me being so anal, it would be nice if it all matched.
ianhurley20
posted on 31/8/17 at 12:20 PM Reply With Quote
Difficult one to answer but from the pictures it seems those parts needing welding will not normally be on show so I would simply paint them a matching colour and before doing so sand the powder coat so there are no steps and when painted these would hide reasonably well. Powder coating is not cheap and to prepare the chassis for a new coat would probably involve stripping it back to bare metal again - that would not be cheap either. Then again I am no expert and I am sure there are a few experts on this forum who will advise.
Are you sure you won't take 20
written off 23/9/18
jps
posted on 31/8/17 at 01:21 PM Reply With Quote
Unless you've done this before - I suspect that the experience of building a kit car will sooner or later bash that attitude out of you! I started off with an impression of what quality of finish, etc would satisfy me - but have had to understand that there's a 'good enough' position which will allow me to actually finish the car within my life time!!!
New Topic New Reply
