Author: Subject: Fiesta ST150 Duratec
snapper
posted on 7/8/17 at 06:27 PM Reply With Quote
Ticking noise top end of my 2.0L Duratec, does this have solid or hydraulic lifters on the standard engine?
I eat to survive
I drink to forget
24vseven
posted on 7/8/17 at 06:42 PM Reply With Quote
Solid lifters still available from ford or burton power.
[Edited on 7/8/17 by 24vseven]
big_wasa
posted on 7/8/17 at 06:45 PM Reply With Quote
I know you say top end but these are really common to do in the big end bearings.
snapper
Thanks, I have a tappy top end so need to identify the problem and thought maybe hydraulic lifter failing.
More diagnostics to do
I eat to survive
I drink to forget
snapper
posted on 7/8/17 at 07:00 PM Reply With Quote
I posted before seeing your reply, thanks.
Tapping comes and goes at certain revs and big ends would knock from idle
Of course I will properly investigate
I eat to survive
I drink to forget
Nathsx
If its bottom end youll hear it at 3k best
snapper
posted on 7/8/17 at 08:17 PM Reply With Quote
Pretty sure it's not bottom end, did the screwdriver test and its sounds top end exhaust cam side
I eat to survive
I drink to forget
Dick
posted on 7/8/17 at 08:27 PM Reply With Quote
Check the exhaust manifold to head gasket b4 you go to far have seen these give a noise that sounds like a tappet going
snapper
posted on 7/8/17 at 08:29 PM Reply With Quote
Thanks I'm on that as have been caught out on a Pinto before.
Did the screwdriver test on that as well
I eat to survive
I drink to forget
davidimurray
posted on 8/8/17 at 07:09 AM Reply With Quote
What about the cam chain?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
snapper
posted on 8/8/17 at 07:52 AM Reply With Quote
No noise from that end of the engine but I'm aware that they can go.
I eat to survive
I drink to forget
davidimurray
posted on 8/8/17 at 08:42 AM Reply With Quote
Is this a stock engine setup? Could it be something like EGR valve or a gas leak? I suppose worn buckets could be an option. If you have a look in my Duratec swap gallery in my signature lots of photos of the engine in pieces.
snapper
posted on 8/8/17 at 06:02 PM Reply With Quote
Yes I really need to get down in the weeds with this one
It's my Fiesta ST150 daily with 136,000 and I ring its neck daily
The trouble is that both kit cars are otherwise indisposed.
I eat to survive
I drink to forget
