Author: Subject: Ford 7inch lsd
goaty
posted on 28/8/17 at 10:36 AM Reply With Quote
Ford 7inch lsd
Hi
After an aftermarket lsd diff to go in a ford 7 inch diff please.
Or what other options anyone have?
femster87
posted on 28/8/17 at 10:43 AM Reply With Quote
what ratio
goaty
posted on 28/8/17 at 04:15 PM Reply With Quote
Plan to build into my current diff
CosKev3
posted on 28/8/17 at 04:49 PM Reply With Quote
If you've got push in shafts it will make it much easier/cheaper if you fancy a Quaife,if you have bolt on shafts to use the ATB you have to also buy the stupidly expensive Quaife output flanges
goaty
posted on 28/8/17 at 06:17 PM Reply With Quote
Looks like i'm in luck as they are push in.
Was planning just to stick with it for cost reason, can also have it all set up when fitted as most the old cossie diffs are worn out by now.
Hopefully something will pop up, Quaife would be ideal
