Author: Subject: Duratec rings
jamriggsy
posted on 6/9/17 at 05:06 PM Reply With Quote
Duratec rings
In my low cost build I'd just like to check whether changing the rings is essential or not.
I have measured all cylinders and they are all within 0.0002" of each other and round and the existing top compression ring gap is 0.014" on all cylinders so I was not going to bother changing them
My essential list of bits to change are
Con rod bearings
Con rod bolts
Friction washer
Crank bolt
Flywheel bolts.
Head gasket
Any advice or things I should add (as in must add rather than just optional) when I populate my shopping trolley from burtons.
Many thanks
Barkalarr
Contributor
Posts 940
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 6/9/17 at 07:35 PM Reply With Quote
I don't know the answer to the above, but I have a job lot of duratec spares most of which are mountune and Cosworth acquired from ford motorsport at Boreham when it closed. There must be about 70 cams, clutches, flywheels, Pistons etc there are LOADS of bits...
I'll upload some pictures tomorrow if you're interested.
Hornet
posted on 6/9/17 at 09:46 PM Reply With Quote
Hi m8 did you take compression readings before stripping? Seems a shame to do all that work and put old rings back in. Same could be said about oil stem seals. With regards friction washer.... it's 2 you will need and it's safe to reuse your crank bolt.
jamriggsy
posted on 7/9/17 at 05:52 AM Reply With Quote
Barkalarr
Yes definitely would be of interest.
Hornet.
Yeah I took comp reading 250.235.240.170.
I have since discovered that cylinder 4 doesn't seal in the valves.
I do agree that while I'm in this position I really should change most bits but just don't have the funds so need to be frugle. If it hasn't been for the low compression on 4 I wouldn't have even taken the head off.
Crank bolt reused?. I'm surprised considering.
davidimurray
posted on 7/9/17 at 09:45 AM Reply With Quote
When I rebuilt mine I found that the piston rings and oil control rings were seriously gummed up. I was going to change the rings, but found that you can get a set of brand new rings, pistons and con-rods from a factory crate engine for only £40. Try a few engine builders as they often take out brand new components to replace with upgraded items and are just looking to make a few quid back. Was cheaper than a set of rings!
Have a look for my Duratec engine swap thread as there are photos of my rebuild on there.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
jamriggsy
posted on 7/9/17 at 11:42 AM Reply With Quote
Brilliant idea if I can find someone. I'll phone around the builders.
davidimurray
posted on 7/9/17 at 02:24 PM Reply With Quote
Might be of interest, but be careful, auction is just for 1 - you should be able to do better - Ford Focus, Mondeo, ST150, Galaxy, S Max, 2.0L Duratec HE Piston, Conrod, Rings
[Edited on 7/9/17 by davidimurray]
neilp1
posted on 7/9/17 at 06:26 PM Reply With Quote
Many thanks
By your friction washers from caterham they cost "washers" from caterham compared to Burtons.
davidimurray
posted on 7/9/17 at 08:46 PM Reply With Quote
Many thanks
Good point, check Caterham for various parts, I remember they were they cheapest place for a mechanical thermostat as well as the friction washers
