Author: Subject: Is anyone using a 2 wire Bosch IAC Valve with Megasquirt
r1_pete
posted on 10/9/17 at 08:57 PM Reply With Quote
Im trying to figure which valve to use, would prefer MS setting 'moving only' so the valve is only powered when pintle movement is needed.
Thinking about a Bosch 0 280 140 512. Does anyone know if this valve is compatible with moving only??
Cheers.
Pete.
obfripper
posted on 10/9/17 at 09:54 PM Reply With Quote
Afaik the valve you've listed is pwm operation, it does work fine with megasquirt but may hum at certain opening amounts.
It does have a limp home mode, that gives partial opening with no voltage applied.
Dave
