Author: Subject: The smallest build garage ??
tompat3463
posted on 17/9/17 at 06:24 PM Reply With Quote
Im very close placing an order for an mint vortx. The only thing putting me off is the size of my garage. It's attached to my house and has a good door. End to end it's 150mm longer than a finished vortx and is about 500mm wider than a garage door so obviously the car will fit. But is this too small to build a car ?
How small was your build garage ?
Pictures would be handy.
Cheers Alan
bi22le
posted on 17/9/17 at 06:40 PM Reply With Quote
I have not built but do maintain my car in a single garage. So it's bigger than yours as I can fit a work bench and a motorbike in mine
I think it will be tight. Can you consider buying a large shed to put all of the parts until you need them, it may also give you somewhere else to work on stuff and pre-assemble.
Please read my ring story:
steve m
posted on 17/9/17 at 06:53 PM Reply With Quote
17 X 8 feet, built from scratch as per "the book"
NEVER AGAIN !!
killerferret666
posted on 17/9/17 at 07:01 PM Reply With Quote
a photo from back when I was building.
Anything is possible
Building DDR GT4
Miami Gt4 Blog - Click Here
big_wasa
posted on 17/9/17 at 07:13 PM Reply With Quote
As Steve, I scratch built mine in a single garage. But I just can't get around to starting another.
SteveWalker
posted on 17/9/17 at 07:38 PM Reply With Quote
My garage was only a few inches wider than the door (I have since widened it by 3 feet). It was fine with a rolling chassis - I just did most of the work outside and then rolled it in at the end of the day or when it rained. I also did some of the work from inside the garage, with half of the car in and a tarpaulin over the exposed half if it rained.
tompat3463
posted on 17/9/17 at 08:00 PM Reply With Quote
Thanks for the replies. It certainly makes me feel better about it.
Daf
posted on 17/9/17 at 08:47 PM Reply With Quote
I have a single garage - slightly bigger but with a motorbike, the kit car, 2 mountain bikes, workbench, kids bikes, lathe, compressor, pillar drill, all my tools and a lot of other crap! Anything is possible!
jps
posted on 18/9/17 at 10:59 AM Reply With Quote
I have a handy source of random scrap - which I know is not the case for everyone - but i got my hands on some heavy duty castors and a pallet and effectively have made a massive dolly which my bare chassis sits on. Although I have a decent size garage - i usually wheel it all out onto the driveway in front of the garage to work on it anyway.
Less of an issue once you get to the 'rolling' stage - but a way to make the best of little space if you have to.
The problem is weather - if it were not typically dry a lot of the time where I live I'd be looking at getting some sort of heavy duty gazebo to pop on the front of the garage. The sort of things people use for trade stands or the like - or even use some box section and tarp to make my own.
Irony
posted on 19/9/17 at 12:28 PM Reply With Quote
Doable but it's a bit rubbish. My garage is 300mm wider than my car and 1000 longer. And a boiler and tumble dryer. You need to be clever with storage etc. So I had shelves above head height all round. A small overhang/porch outside the door so I could push the car out a few feet and still work undercover. Fold down workbench etc. Wall storage for tools. A shed for lesser used stuff.
Small garages take far far less to heat so there is a upside
ian locostzx9rc2
posted on 19/9/17 at 02:02 PM Reply With Quote
As said once the cars rolling it easy plus you can use the inside of the car for storage .
Bluemoon
posted on 19/9/17 at 02:09 PM Reply With Quote
Similar method to me in our single garage, the donor car (Sierra estate) car also made a good temporary "shed" (on axle stands!)...
LBMEFM
posted on 19/9/17 at 08:03 PM Reply With Quote
Looking outside the box as some would say, count yourself lucky I believe many on here have built their cars outside.
ianhurley20
posted on 19/9/17 at 09:37 PM Reply With Quote
I have a roll out caravan awning on the front of my garage - it adds several feet of dry space and helps tremendously with a build.
