New Topic New Reply
Author: Subject: Fitting a polo radiator. Help needed !
nick-york
posted on 17/9/17 at 06:29 PM Reply With Quote
Hi all .I'm going to be fitting a new polo radiator but need to build a frame /brackets to fit it .has anybody got any pictures of how they've fitted one .or any advice much appreciated .Cheers.
SJ
posted on 17/9/17 at 07:41 PM Reply With Quote
I don't have any pics but mine we just made from bits of thin angle steel and fastened to rivnuts in the chassis.
I don't remember it being too tricky to do.
Stu
cliftyhanger
posted on 17/9/17 at 08:37 PM Reply With Quote
If you are unaware,the rad has attachment lugs moulded into the end tanks. They will accept a short M6 setscrew, though in the original fitment something nearer a short fat hex-headed self tapper is used. But do check for available depth.
As above, I used some steel angle....
HowardB
posted on 18/9/17 at 06:21 AM Reply With Quote
Same here, there are self tap holes in the plastic ends,. although apply caution and check the depth
Howard
johnemms
posted on 18/9/17 at 07:44 AM Reply With Quote
Radiator pipes and fan fitted
Front Bay Side
Front Bay Side
polo rad vw gti  fittings
[Edited on 18/9/17 by johnemms]
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
ElmrPhD
posted on 19/9/17 at 10:46 AM Reply With Quote
Suggest using 4 of those (m6) rubber bobbin/cotton-reel thingies to mount, so that:
- Vibration is minimized.
- Corrosion is minimized, if you manage to keep the core from being grounded.
nick-york
posted on 20/9/17 at 07:14 PM Reply With Quote
Thanks for the tips and pictures everybody .Much appreciated. Cheers
New Topic New Reply
