ttalps2000
posted on 1/10/17 at 07:18 PM |
Zetec Windage Tray
Just got my zetec engine and have begun sorting out a few bits on it.
When i got it, the engine had no sump as this had been used on their new engine.
I have a Dunnell sump for it now. Do i need the windage tray with the dunnell sump as well? It currently doesn't have one, but looks like it was
removed as the bolts are partially screwed in.
Any difference between the silvertop and black top versions of the tray?
madteg
posted on 1/10/17 at 07:22 PM |
I have not had one for 10 years and all is still good
r1_pete
posted on 1/10/17 at 10:08 PM |
In reply to your last point, the black and silvertop trays are totally different, silver has a pressed steel tray, held in by double sided bolts on 2
and 4 main caps, the blacktop has a two piece sump, a cast alloy portion which incorporates the tray, and the pressed steel sump, check my
photonarchive for a silver tray on a blacktop and the mods needed.
ttalps2000
posted on 4/10/17 at 12:27 PM |
Spoke to Dunnell today and he said to use the windage tray with their sumps!
