Author: Subject: Polybush hardness
craigdiver
posted on 9/10/17 at 07:56 PM Reply With Quote
Polybush hardness
I have two sets of polybushes, a black set which are very hard with virtually no elasticity - these are fitted to my car and were a pain in the ass to fit/mount wishbones as there is no play. The other set of polybushes I have are made of a more rubbery material and are great to work with.
Will there be a noticeable difference in handling with the softer wishbone bushes? Reason Iím asking as could do with taking front wishbones off to panel the front of the car but the wishbones were a pig to fit with the hard bushes.
[Edited on 9/10/17 by craigdiver]
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
Bluemoon
posted on 10/10/17 at 06:14 AM Reply With Quote
Why is it a pig to fit with the hard bushes? You shouldn't need to remove them from the bones to disassemble..??
View User's Profile View All Posts By User U2U Member   Bluemoon 's Yahoo
craigdiver
posted on 10/10/17 at 07:17 AM Reply With Quote
I bought wishbones that someone else had already made and on a couple of the wishbone bushes they donít line up perfectly so the bolt goes in through the bracket, through the bush tube/polybush/crush tube and is a mm or two out on the 2nd hole in the wishbone bracket. As the polybushes are very hard, takes some persuasion to get through.
Iím not entirely happy with this but too late to change at this stage.
Bluemoon
posted on 10/10/17 at 09:35 AM Reply With Quote
MK's ones are a struggle to get in (the arms deform slightly after welding, i.e. spring out or in a bit) but you can slide the bolts in once in place, and it all moves nice and smoothly. The bushes should be slightly tight on the crush tube diameter, with a little backward and forwards play. The wishbones tend to just drop with there own weight once every thing is bolted up..
craigdiver
posted on 10/10/17 at 10:29 AM Reply With Quote
Originally posted by BluemoonMK's ones are a struggle to get in (the arms deform slightly after welding, i.e. spring out or in a bit) but you can slide the bolts in once in place, and it all moves nice and smoothly. The bushes should be slightly tight on the crush tube diameter, with a little backward and forwards play. The wishbones tend to just drop with there own weight once every thing is bolted up..
Think I need to change out my polybushes - I broke a vice whilst inserting them and are very tight on both the wishbone bush tube and crush tube. A bit of force is required to move the wishbones when clamped up.
procomp
posted on 10/10/17 at 01:46 PM Reply With Quote
Hi.
The currently fitted bushes sound like the usual kitcar ones not much good and the new ones are likely to be genuine poly bushes with a shore rating of 80-85. If wishbones are removed just change the bushes the difference in freedom off movement will be a significant improvement.
Cheers Matt
craigdiver
posted on 10/10/17 at 03:57 PM Reply With Quote
Originally posted by procomp
Hi.
Cheers Matt
Hi Matt, hope all is well.
The current ones are solid, the other ones feel a bit more rubbery and can be deformed slightly if squeezed by hand.
craigdiver
posted on 11/10/17 at 04:27 PM Reply With Quote
Matt, you were spot on. Took one of the wishbones off and replaced the hard bushes with the softer ones and what a difference in refitting the wishbone and much easier movement once tightened. You can actually feel the bracket tightening down onto the crush tube.
Only 20 more to replace ;-0
OliilO
posted on 12/10/17 at 09:17 AM Reply With Quote
Where is the best place to get wishbone bushes from? I need to replace some on my car shortly.
craigdiver
posted on 12/10/17 at 10:15 AM Reply With Quote
That is a great question, wish I had known, would have saved me £50 or so on the wrong ones.
