Author: Subject: Cleaning up rear diff and gearbox.
hazardpro
posted on 16/10/17 at 01:25 PM Reply With Quote
I can degrease them with 'Gunk' but do people generally use to paint them? Spray them? Any specific type of paint or just good old spray paint?
Thanks in advance.
H
posted on 16/10/17 at 01:43 PM Reply With Quote
Gave mi Sierra diff a brush off with a stiff broom and fitted it to the Indy.
Washed the g/box off with Gunk (or similar) and fitted it back on to a rebuilt Pinto.
No paint involved for me as you can't see those bits once finished anyway.
hazardpro
posted on 16/10/17 at 01:45 PM Reply With Quote
Very true but my OCD wont allow me to do that lol
40inches
posted on 16/10/17 at 02:10 PM Reply With Quote
De-grease, jetwash And rotary wire wheel, then a few coats of Eastwood Spray Grey Paint, not the cheapest but goes a long way
https://www.frost.co.uk/automotive-paint-coating-electroplating/automotive-paint/eastwood-paints/eastwood-spray-gray-grey-paint-340g.html
posted on 16/10/17 at 02:53 PM Reply With Quote
Get your point, but focus on getting it finished, tested, registered and driving it.
There's a lot of people take a very long time building and then don't get it finished!
SJ
posted on 16/10/17 at 03:00 PM Reply With Quote
One man's dirt is another man's patina.
cliftyhanger
posted on 16/10/17 at 03:08 PM Reply With Quote
Jetwash good for getting 99% of the crap off but most seems to end up on you (me)
Finish with gunk/washing powder/whatever.
Prime ally (if you must paint it) with etch primer. That works well on bare steel/iron too.
Chassis black is pretty good stuff. Or almost any black household paint or decent quality.
hazardpro
posted on 16/10/17 at 03:15 PM Reply With Quote
Its all of the above already Just changing clutch so while its out want to clean it up
Thanks guys
@40inches - thats what Im talking about! Nice one
mark chandler
posted on 16/10/17 at 03:51 PM Reply With Quote
And while its apart tear around the bell housing with a 2" hole saw and get rid of some weight!
steve m
posted on 16/10/17 at 04:14 PM Reply With Quote
Have to say, that I will always paint back axles gearboxs etc, it just gives a better look, and cleaner
But I didn't drill holes everywhere like Mark says, but I did grind off the bottom of the gear box to aid in ground clearance,
so the whole edge of the box is now about 10mm, not 40mm deep,
steve
hazardpro
posted on 16/10/17 at 04:18 PM Reply With Quote
steve
Hmm thats a good idea. Its a bit tight down there!
shindha
posted on 16/10/17 at 05:39 PM Reply With Quote
Hi is that finish on the bell housing using the Eastwood paint? as that is very neat - like it a lot.
40inches
posted on 16/10/17 at 08:52 PM Reply With Quote
Yep! Two coats, no primer. Very tough paint, sticks to anything It's not very grey though.
Bluemoon
posted on 17/10/17 at 09:08 AM Reply With Quote
^^ good finish is about prep, that casting is nice and smooth..
40inches
posted on 17/10/17 at 10:30 AM Reply With Quote
The wire wheel made all the differance
jps
posted on 17/10/17 at 10:55 AM Reply With Quote
Do you have a before picture? I have cleaned my Type3 gearbox a LOT and the mainbody of the case is silver like yours (i'm assuming it's aluminium) but the bellhousing has stayed black - despite being well degreased...
posted on 17/10/17 at 04:23 PM Reply With Quote
On my type 9 the bell housing was steel and the gearbox case was Aluminium.
40inches
posted on 17/10/17 at 05:40 PM Reply With Quote
The photo is after degreasing(with Machine Mart solvent degreaser, I have no faith in water based ones) and jet washing, but before the wire wheel.
