Author: Subject: Wanted Escort/ capri axle.
macc man
posted on 27/10/17 at 05:51 PM Reply With Quote
Looking for a complete Escort or Capri rear axle for a hot Anglia project. Willing to travel within reason to collect.
Thanks Henry.
[Edited on 27/10/17 by macc man]
shindha
posted on 28/10/17 at 05:26 AM Reply With Quote
I think these cars had two different types of axles, namely the English axle and the Atlas axle. The English being stronger and the preferred choice, but very rare, Ebay is worth a look.
steve m
posted on 28/10/17 at 06:52 AM Reply With Quote
I also believe the Capri axle is 2" wider than the escort one, so worth checking
big_wasa
posted on 28/10/17 at 08:24 AM Reply With Quote
Capri Atlas is stronger but heavier and 4” wider than an English Escort axle. Avoided a Koln,it looks like an atlas but a little narrower. Then here are cortina’s ect.
Fandango
posted on 28/10/17 at 12:31 PM Reply With Quote
I have a spare axle.
I got it as part of a spares package when I bought my (ex 750mc ) Locost.
If anyone can give me a clue how to identify it, (I can`t see a serial number anywhere, but it does have a barely legible sort of dog tag on it), then it may be suitable.
Numbers on "dog tag" OE20N3891, P75AG4004BVC.
Width is 1230mm to the face where the drum backplate fits.
[Edited on 28/10/17 by Fandango]
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me." Hunter S Thompson
big_wasa
posted on 28/10/17 at 06:19 PM Reply With Quote
Ratio will be 3.89:1
For the 750 mc Locost I would think it’s an Escort English axle.
With an English axle the diff unbolts from the casing (banjo) and the atlas has a tin cover on the rear of the axle to get to the diff.
Fandango
posted on 29/10/17 at 09:03 AM Reply With Quote
Cheers Big Wasa
The rear casing is part of the whole, ie not removable. To dismantle, you would split from the front aspect, there are 8 nuts holding it together, via captive bolts.
Can we confirm which it is now?
ian locostzx9rc2
posted on 29/10/17 at 03:10 PM Reply With Quote
English axle as fitted to mk1 and 2 escorts anglias etc...
posted on 29/10/17 at 04:57 PM Reply With Quote
Do you have to have a Ford axle? Theres plenty live axles around from 4x4s with lsds and disc brakes as standard..
