Author: Subject: what material could I use for this template
killerferret666
posted on 10/11/17 at 03:49 PM Reply With Quote
I want to make a new diffuser template and it has a bend to it, not stupidly sharp but tight enough.
Hardboard is just a bit too tough and corregated cardboard doesnt bend smoothly. Does anyone have any suggestions?
Obviously the cheaper the better...as it will be thrown away eventually.
Building DDR GT4
Miami Gt4 Blog - Click Here
Sam_68
posted on 10/11/17 at 05:44 PM Reply With Quote
How big does it need to be?
Would mountboard (stiff card for mounting pictures) do the job... readily available up to 60" x 40" size?
Is thin (2.5mm) MDF still too stiff?
steve m
posted on 10/11/17 at 06:24 PM Reply With Quote
corex, the stuff for sale signs are made out of ?
bi22le
posted on 10/11/17 at 08:28 PM Reply With Quote
Project Binky would use CAD, even for bends.
CAD = Cardboard Aided Design.
Please read my ring story:
myke pocock
posted on 10/11/17 at 10:29 PM Reply With Quote
Cornflake packet, other similar products are acceptable!!!
killerferret666
posted on 11/11/17 at 09:15 AM Reply With Quote
The size is up about 2metres wide by 60cm high so quite big!
Building DDR GT4
trextr7monkey
posted on 11/11/17 at 05:39 PM Reply With Quote
Check out flexi ply comes in various thicknesses and used to laminate nice flowing shapes I think Wickes sell it in some stores but it isn’t a cheap product
Maybe if you bought a full sheet of thin flexi ply you could easily laminate your desired shape. You could sell the leftover bit to some one on here
Atb
Mike
jossey
posted on 11/11/17 at 05:42 PM Reply With Quote
Cardboard from. An art shop like 800gram
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
r1_pete
posted on 11/11/17 at 07:09 PM Reply With Quote
Cerial box, if its not stiff enough when formed, paint it in polyurethane varnish..
907
posted on 11/11/17 at 09:33 PM Reply With Quote
I would use metal.
A sheet of thin bright mild steel could be a fraction of the price of the final more exotic material.
Paul G
The one and only member of the Suttol Owners Club. Now also the MX5 Owners Club. A few more in that one.
Angel Acevedo
posted on 13/11/17 at 01:22 AM Reply With Quote
Here in Carmen I use Sam´s Club,
A lot of products come with cardboard separators that are thicker than Cereal box cardboard.
you should have something like that.
It´s free, and I can take as many as I want.
They are about standard Pallet dimensions, but you can tape two sheets (or more) together
HTH
gremlin1234
posted on 13/11/17 at 05:05 PM Reply With Quote
apparently there is a board called Essex Board often used for curtain pelmet boxes.
a quick search found this supplier and info, and apparently any proper wood-yard should be able to supply it
http://www.ukcurtainpoles.co.uk/acatalog/Essex-Board-609mm-x-2185mm-Pack-of-5-4703R.html
miskit
posted on 13/11/17 at 05:10 PM Reply With Quote
I have some great stuff that they use for printing hoarding signs on - mine came from Waitrose signage round building works. Its a white painted aluminium sandwich with a plastic in the middle, about 3mm thick in total. Comes in sheets 10ft x 4ft I think.
I bought loads and used a lot of it as clean walls in my food business. It is also fantastic for templates as it is rigid, easily drilled and you can cut it with a blade. Cut just one alu side and it folds to any angle and holds it. Search for Dibond but I am sure there are others.
killerferret666
posted on 13/11/17 at 05:32 PM Reply With Quote
Thanks all, ill work my way through these ideas
Building DDR GT4
