Author: Subject: WTD: Zetec Blacktop log manifold
pekwah1
posted on 20/11/17 at 02:59 PM Reply With Quote
Hi Guys,
Just wondered if anyone has an intake manifold lying around suitable for a 2.0 blacktop zetec.
i intend to use it with the standard injectors and throttle body.
Thanks,
SJ
posted on 20/11/17 at 03:43 PM Reply With Quote
I think I have a plastic 1.8 one, which I believe is the same as the 2.0. I have a 2.0 one as well but the numpties delivering my engine managed to break it.
Would need to have a rummage in the garage to confirm though.
pekwah1
posted on 20/11/17 at 04:00 PM Reply With Quote
Sorry, didn't write this very well, i'm after something that looks a bit like this:
[Edited on 20/11/17 by pekwah1]
SJ
posted on 20/11/17 at 04:20 PM Reply With Quote
Sorry - I see what you are after now.
Stu
chris
posted on 20/11/17 at 11:05 PM Reply With Quote
GBS sell similar but pricey https://s18.postimg.org/b8gdksmex/plenum.jpg
[Edited on 20/11/17 by chris]
knight19770
posted on 21/11/17 at 08:45 AM Reply With Quote
Hi Andy,
Here is one that i have ordered from the Scottish kit car centre? Worth a look and they supply the standard ecu with pre wired loom aswell, all plug and play.
http://www.kitcarparts-scotland.co.uk/ford-2-0-zetec-maxi-torque-inlet-manifold/
Mike
blobster7
posted on 21/11/17 at 09:05 AM Reply With Quote
u2u
U2u sent. Regards Jim.
angliamotorsport
posted on 21/11/17 at 07:08 PM Reply With Quote
Hi, I have an unused GBS zetec inlet and throttle body 150 plus post
tims31
posted on 22/11/17 at 04:56 PM Reply With Quote
I've used one of these and it works fine. The only trouble I had with it in the Fury was the throttle arm, if you have your foot flat down and the rocker arms are fully extended it holds the throttle open
I got around this by reorienting the arm. See here
Build: http://www.martinsfurybuild.co.uk/
angliamotorsport
posted on 22/11/17 at 05:09 PM Reply With Quote
Good information but only needed if you have a Fury
tims31
posted on 23/11/17 at 03:54 PM Reply With Quote
Or maybe another Chassis with inboard shocks/dampers. Just a note of caution as I found out after purchasing one.
pekwah1
posted on 23/11/17 at 04:29 PM Reply With Quote
thanks all, i now have a manifold sourced!
