Author: Subject: my locost is too low at front?
alfas
posted on 22/11/17 at 05:18 PM Reply With Quote
Mk Locost, , x/flow powered. Original 12" shocks with far too long coils.
actual situation:
coil platform on spax-shocks are already winded down to lowest point.
watching the car from front upper whsibones are parallel to the ground
lower wishbones and steering tie-rods are inclined towards wheel
we all know that the ideal situation would be lower wishbones parallel.
ok..this said i have purchased some shorter coils and set them up that the
lower wishbones are parallel to the ground (automatically the tierods also came nearly parallel)
upper wishbones are now inclined upwards (towards wheel)
now the car sits very low...imo not on the limt, but for a road car already too low (i will use it only on the track anyway)
anything i can do? not much i guess?
mark chandler
posted on 22/11/17 at 07:38 PM Reply With Quote
Drop the back so it's 1/2" higher than the front, job done
If it's scraping on the road it's to low!
adithorp
posted on 22/11/17 at 07:51 PM Reply With Quote
Wishbone tubes parallel with the ground (how it reads to me) or an imaginary line between centre of the ball joint and the inner pivot bolt (which is what you want)?
http://jpsc.org.uk/forum/
alfas
posted on 22/11/17 at 08:18 PM Reply With Quote
hmmm...which should be favoured?
just a shrt sketch: red-- before, blue after (just a sketch about the inclination)
alfas
posted on 22/11/17 at 08:21 PM Reply With Quote
do you mean this line?
mark chandler
posted on 22/11/17 at 10:38 PM Reply With Quote
Blue, you are now correct
40inches
posted on 22/11/17 at 11:08 PM Reply With Quote
Blue!
motorcycle_mayhem
posted on 23/11/17 at 09:25 AM Reply With Quote
The correct wishbone geometry sets the ride height, so, if it's too low you'll need bigger tyres/wheels or to move the stub axle up a tad in a fabricational way.
If you're not on a track and/or don't require the best handling/camber control/etc./etc., then just wind up the platforms.
posted on 23/11/17 at 10:00 AM Reply With Quote
My thoughts...it's about pivot point centre points, not the wishbone tubes.
As I understand it the pivot point centres of the lower front wishbones should be parallel to the ground.
[Edited on 23/11/17 by nick205]
alfas
posted on 23/11/17 at 11:32 AM Reply With Quote
ok...got it....with the pivot-point-line parallel i will gain further ~10 to 15mm (i guess) on height....so the fnal result will be fine for a track car.
sure you can always move things higher by fitting bigger wheels...but i need to consider having a x/flow with around 100BHP fitted....if the wheels are too big, that small engine will not have enough power anymore to accelerate the car properly....which means fitting a shorter diff....so this becomes and endless story.....
i also need to put into consideration fitting wheels where i get racing tyres for. so the choice is not as big as with a road-car.
coyoteboy
posted on 23/11/17 at 02:24 PM Reply With Quote
What's too low? 100mm should be fine for all but the biggest speed bumps.
alfas
posted on 27/11/17 at 12:48 PM Reply With Quote
today i viewed several pictures of rather modern caterhams...
interestingwise all are set with the lower wishbones parallel to ground
the "theorectical line" between pivot points would mean a different setting.
after this i searched around the web and found lots of entries in different forums around the world...all are talking about "set lower wishbones parallel to ground"
"The rule of thumb for a seven still stands - parallel front lower wishbones "
now i´m confused...are all those cars wrongly setted?
[Edited on 27/11/17 by alfas]
coyoteboy
posted on 27/11/17 at 12:56 PM Reply With Quote
The simple answer is...not simple. There may be an "as designed" position, but it's not wrong to modify suspension settings for an individual choice/feel/tyre setup, shock type etc. There's a starting point, and some rules of thumb, but any car like this has adjustability built in.
procomp
posted on 27/11/17 at 02:29 PM Reply With Quote
Hi.
Its quite straight foward to get the best rideheight set but alot off the above is just typpical internet myth being recycled.
1. What size tyres are fitted.
2. What uprights.
3. How far is sump below chassis rails.
If you wish send u2u.
I
alfas
posted on 27/11/17 at 10:03 PM Reply With Quote
but the old cat/lotus cars had a triumph trunion as lower pivot point on the uprite. on those cars the pivot centre was definately above the wishbone...like on locost´s or westifields....but also those cars are mostly set with lower wishbones parallel.
bumpsteer is the related problem i think...
alfas
posted on 30/11/17 at 09:42 PM Reply With Quote
today i recognized that the maxi balljoint is mounted, as with most seven-ish cars, above the lower wishbone.
if it would be mounted below, than the pivot-point line would also come lower, so more into direction of "lower wishoine should sit parallel".
good idea, bad idea, crazy idea?
Irony
posted on 1/12/17 at 09:44 AM Reply With Quote
u2u me your email if you want a bigger version of this page
[Edited on 1/12/17 by Irony]
alfas
posted on 3/12/17 at 12:10 AM Reply With Quote
sent u2u
