Author: Subject: Mounting a RX8 Gearbox
sammini7
posted on 13/12/17 at 08:26 PM Reply With Quote
Hi Guys
Has anybody mounted a Mazda RX8 6 speed gearbox in a Locost chassis, If so what mounts did you use? Do you have any pictures?
Kind Regards
jossey
posted on 13/12/17 at 10:04 PM Reply With Quote
I looked into this a while off and trial fitted the box and copied this mount.
Rx8box
Rx8box
bolts into the chassis underneath. Then I thought I could have it to bolt inside the tunnel so modified it to have uprights on it the bolt from inside the cab. Didn't work out so need to make another.
David Johnson
posted on 15/12/17 at 12:56 PM Reply With Quote
jossey - what car is that?
jossey
posted on 15/12/17 at 01:20 PM Reply With Quote
That's not my car it's a guy I'd spoke to on a forum ages ago who was doing a eco boost to rx8 conversion. No idea on car but I'd say anglia as a guess.
David Johnson
big_wasa
posted on 15/12/17 at 08:47 PM Reply With Quote
I am thinking the 5 speed rx8 box looks a better bet for fitment to a Locost.
[Edited on 15/12/17 by big_wasa]
jossey
posted on 15/12/17 at 10:25 PM Reply With Quote
Ye and very cheap still. I have 2 and paid under,, £100 each
David Johnson
big_wasa
posted on 15/12/17 at 10:31 PM Reply With Quote
Have you got one in yet ?
How did a T9 stand up to your turbo ? Cheers...
Ugg10
posted on 15/12/17 at 11:37 PM Reply With Quote
It’s my anglia 105e. I canned this idea and made up a rear mount using the usual cortina mount, just happened to line up with one of the cross members. Pics on my build thread, link in signature.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
jossey
posted on 16/12/17 at 09:12 AM Reply With Quote
Actually run the mt75 box on the turbo it's a bit stronger than the type 9 but has been great so far. Which is surprising. I've done about 22 track days. Which is about 4800 miles total including my road driving.
Have trial fitted the box and engine into the Westy but had an issue with prop being a few inch too long and I didn't want to remove it.
David Johnson
big_wasa
posted on 16/12/17 at 09:42 AM Reply With Quote
Thanks for the info. I used the mt75 in my last build as I new it would handle what ever I put through it. I have a 30 year old T9 in this one and doubt it will last long with 250/250 through it.
jossey
posted on 16/12/17 at 10:07 AM Reply With Quote
Ye agreed. Other thing with the mt75 is it is a little narrower. I'm. Only running 269 now on 14psi of boost so the rx8 box would be fine. Plus ratios are much better if you ignore 1st.
Good luck pal. Get in touch if I can help. The mt75 allowed me to out a bigger charge cooler up front..
Muchmoreroom
Muchmoreroom
[Edited on 16/12/17 by jossey]
David Johnson
big_wasa
posted on 16/12/17 at 10:14 AM Reply With Quote
The rx8 5 speed looks a little narrower than the mt75, Is that not the case ? 6 speed looks wider.
jossey
posted on 16/12/17 at 10:18 AM Reply With Quote
The 6 speed is less than an inch wider in the places it with hit a Westfield tub and an inch wider toward the prop. So shouldnt worry me. Sorry I've not seen a 5 speed but I thought the case was the case but I've not researched them at all sorry pal.
David Johnson
big_wasa
posted on 16/12/17 at 10:24 AM Reply With Quote
Now making this rwd, I don’t think there will be much left by the time I am done as I am changing the inlet, exhaust mani, sump, alternator.
I chose the water to air charge cooler setup as it was going in a midi. Can I ask why you use it over a front mount air to air intercooler as I am weighing up my options there as-well, thanks again.
jossey
posted on 16/12/17 at 02:23 PM Reply With Quote
We used the space at the front to fit a charge cooler and 2 rads in front of the normal radiator for space. I've removed one of the rads from the charge cooler as it made little difference to the temps. Especially when we use ice in the expansion tank before we race it. Gets air temps down to 23c on a hot day. Which is impressive after 2 hours at a track.
David Johnson
