Author: Subject: MIG welding trolley gas bottle support
posted on 5/1/18 at 09:39 AM Reply With Quote
Morning all,
A while back I fabricated myself a wheeled trolley for my MIG welder using box section tube. On the rear I built a low "shelf" arrangement for the gas bottle to sit on. The bottle is then tied to the trolley with a couple of ratchet straps. This works, but I'm thinking it should be better supported.
Quite happy to weld more parts etc.
Does anyone have any suggestions or perhaps pictures of how there's are done?
Thanks,
Nick
dinosaurjuice
posted on 5/1/18 at 10:59 AM Reply With Quote
I welded some 6mm steel bar on the back. If i change bottle size ill just grind it off and weld a new piece on
posted on 5/1/18 at 11:37 AM Reply With Quote
Thanks - certainly feasible with what I've already got!
40inches
posted on 5/1/18 at 12:49 PM Reply With Quote
My bottle is held in place with a large worm drive band. Worked ok for the last 20 years
r1_pete
posted on 5/1/18 at 02:35 PM Reply With Quote
My machine has a chain which wraps round the bottle on hooks each side, supports a 50L bottle ok.
posted on 11/1/18 at 10:23 AM Reply With Quote
Getting my Argoshield bottle refilled in the next week or so which frees me up to make modifications to the trolley
Angel Acevedo
posted on 11/1/18 at 06:44 PM Reply With Quote
Mine has too...
And in my case, I think it´s plastic chain..
Plastic chain is pretty strong to keep the cylinder in place.
I reckon the machine will topple before the chain fails.
I may be wrong... And wouldn´t want to learn the hard way.
I have not had done anything to the machine. The machine came with aforementioned plastic chain.
