Author: Subject: Fuel return
melly-g
posted on 5/1/18 at 03:13 PM Reply With Quote
Fuel return
Would it be OK to use 3/16" (brake pipe) as the fuel return on my swirl pot setup?
There wouldn't be issues with pressure build up would there?
I know it would be good to have a bit of back pressure so the lift pump isn't flat out all the time, is it an idea to have restrictor in line?
if so what size?
SPYDER
posted on 5/1/18 at 03:42 PM Reply With Quote
I have a restrictor ( about 2mm IIRC) in the tank return from my swirlpot together with a "Fuel King" filter/regulator just after the LP pump which is set at 2psi.
You do want reasonable flow back to the tank to help prevent temperature build up. I put a small copper coil cooler in the line returning from the fuel rail to the pot. Every little helps.
Your 3/16 pipe might be restriction enough. The sound of your LP pump should give you a clue. You could measure the flow before and after the 3/16 pipe.
melly-g
posted on 20/4/18 at 03:32 PM Reply With Quote
Was it a coil you made or a proper cooler/coil?
Have to got any images of it?
Is it in cool air flow?
