Author: Subject: Wanted carbon fibre sheet
chicade
posted on 14/1/18 at 11:51 AM Reply With Quote
As per title Im after some real carbon fibre sheet to do my tunnel top and rear boot cover on my Mk indy 0.5mm is ok as I can go over the existing plastic if needs be or 2/3 mm if replacing
Tonesta
posted on 14/1/18 at 01:36 PM Reply With Quote
Hi
try nvcarbon search for them in google is easiest
peter030371
posted on 14/1/18 at 02:02 PM Reply With Quote
I have used CF for tunnel top, sides and part of the front bulkhead+scuttle on my Striker and its about 1.2mm finished thickness. This is instead of aluminium and is much lighter (about half the weight) and so far seems plenty strong enough. I had mine sitting around for years (about 12!) but other than Carbon-NV you can also try Easy Composites who look a little cheaper or ebay.
I got some Perma-Grit tools (sanding block and jigsaw blade) from Easy Composites to make it easier and neater to work with carbon.
[Edited on 14/1/18 by peter030371]
APR
posted on 14/1/18 at 03:52 PM Reply With Quote
found this
http://www.kitcardirect.co.uk/westfield/westfield-bodywork/carbon-sheet-110cm-x-47cm.html
SPYDER
posted on 14/1/18 at 04:13 PM Reply With Quote
Carbon tunnel? Couldn't agree more! We did ours in 1mm sheet sourced through the back door of a local factory. The sheets were seconds but it doesn't show. Easy to cut with a treadle guillotine or bench knife.
peter030371
posted on 15/1/18 at 08:33 AM Reply With Quote
I do like the look of your chassis
but how do you cut carbon with a knife?
SPYDER
posted on 18/1/18 at 03:14 PM Reply With Quote
Sometimes called bench shears. We always called it a bench knife.
peter030371
posted on 18/1/18 at 03:34 PM Reply With Quote
That makes more sense now I had images in my head of you slicing through carbon with a Stanley knife
