New Topic New Reply
Author: Subject: MK Indy R - Zetec and type 9
Daz1234
posted on 15/1/18 at 08:57 PM Reply With Quote
Hi all
Am I going mad??? I have a IndyR frame (mid build)... intending on running a Zetec black top and type 9 gearbox.
I have just gone to 'size things up' and there is no way in hell its all going to fit.
Based on where the engine mounts are located I can easily work out where the engine will sit, and where the bell housing needs to be.
The bell housing will need to sit approx 4" within the tunnel. Problem is the tunnel is (just shy) 12" .... and my bell housing is a good 13" wide, with the widest part being where the starter motor is.
Same as this:
http://www.retro-ford.co.uk/shop/sites/default/files/image cache/product_full/004_5.JPG
Doesn't matter how I position it is def will not fit inside the tunnel.
Am I missing something?? HELP
Daz.
furryeggs
posted on 15/1/18 at 10:21 PM Reply With Quote
You may find the bell housing isn’t meant to be IN the tunnel, If the indy is anything like my tiger you’ll need a extension on your gear stick to move the position backwards and from under the dash.
CosKev3
posted on 15/1/18 at 10:28 PM Reply With Quote
Have you bought the chassis new?
Just hope it's not a BEC chassis!
Daz1234
posted on 15/1/18 at 10:33 PM Reply With Quote
Thanks but that's not it. The engine can only fit in one place which then determines where everything else goes
Daz
Daz1234
posted on 15/1/18 at 10:35 PM Reply With Quote
Purchased new from MK with zetec engine mounts welded in place.
It the tunnel a different width then on a BEC mk indy r? I can't really see how the tunnel could be any wider or indeed shorter :/
It's got me stumped. Will call them tomorrow.
Daz
CosKev3
posted on 15/1/18 at 10:37 PM Reply With Quote
Perhaps they've just welded the mounting plates in the wrong place?
Or had a mix up with your order and welded them in for a different engine.
kingster996
posted on 15/1/18 at 10:52 PM Reply With Quote
Does the bellhousing have a lump on it for the starter?
That might need lopping off as the starter doesn’t sit inside the housing. Then you might have room. That’s what you need to do for a Westy chassis anyway.
I used to be indecisive, but now I'm not so sure
Daz1234
posted on 15/1/18 at 10:54 PM Reply With Quote
Interesting... hopefully some Indy owners may see this too and be able to clarify.
I sure hope it's not a issue with the frame as I'm months into the build!
Daz
kingster996
posted on 15/1/18 at 11:02 PM Reply With Quote
Looking at the pic you posted, same bellhousing as mine, and you remove the huge bit that gets in the way basically. Probably the same for an Indy
Daz1234
posted on 15/1/18 at 11:06 PM Reply With Quote
Thanks for the reply
- guess that would work
Still seems like it would be right on the other side for the clutch.....
Will see what MK say in morning - fingers crossed!
Thanks for your help
posted on 16/1/18 at 12:16 AM Reply With Quote
Id be cutting the chassis up to get the engine as far back as possible, helps weight distribution and puts the gearstick just where you want it..
40inches
posted on 16/1/18 at 09:15 AM Reply With Quote
You will gain 2" by fitting the panel on the inside of the chassis.
But as kingster said, cut that lump off the bell housing, it doesn't do anything.
CosKev3
posted on 16/1/18 at 09:30 AM Reply With Quote
Pretty sure the Indy R chassis is totally different to the older Indy,it's all round tube for sure
Daz1234
posted on 28/1/18 at 06:35 PM Reply With Quote
Got it to fit by cutting a big chunk of the bellhousing off. Its bloody tight though!
I now have a gaping hold in my bellhousing though - does that matter? Eg dust and crap up off the road etc?
Daz
CosKev3
posted on 28/1/18 at 07:29 PM Reply With Quote
Probably not,but personally I would weld a plate over the hole
New Topic New Reply
