Author: Subject: Preparing wires for crimping
John G
posted on 3/2/18 at 03:53 PM Reply With Quote
I have just purchased a box of plastic insulated connectors. After stripping the insulator is there anything worth putting on the copper wire to prevent them from corroding in the future?
John
Angel Acevedo
posted on 3/2/18 at 04:46 PM Reply With Quote
John
I have seen telephone Junction boxes that come with a gel covering the contacts where you plug the telephone cord.
Wonder if an electronics store may have something like that.
trialsman
posted on 3/2/18 at 05:23 PM Reply With Quote
I think that grease is called di-electric grease or something like that here in the colonies.
craigdiver
posted on 3/2/18 at 05:46 PM Reply With Quote
as an electrical engineer I use denzo paste (grease) to smear on terminals that are subject to adverse weather conditions or are dissimilar metals (tinned copper terminals on copper wire)
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Abarth 595
Classic Fiat Panda 1000 CLX
Aprilia Mana 850
posted on 3/2/18 at 06:46 PM Reply With Quote
Forget who makes it but Connector Protector is made for the job, think Maplins sell it?
posted on 4/2/18 at 12:14 AM Reply With Quote
If its new wires, then it should not need anything doing, you want metal to metal contact. If it is a Land rover, then copper will have oxidised so rub wire stands with fine wet and dry until shiny.
If you are concerned about corrosion, pack the connector with vaseline or use heatshrink.
I really don't think it's that big a problem.
[Edited on 4/2/18 by 02GF74]
Visit China. Meet the child that made your trainers.
trextr7monkey
posted on 4/2/18 at 01:17 AM Reply With Quote
The stuff Maplinsvsell is called Contralube 40 or something similar
It’s pretty good but as said above may not be needed on new loom
Atb
Mike
posted on 5/2/18 at 09:19 AM Reply With Quote
I've worked in electronics manufacturing for 20 years. Built an MK Indy as well. Never used anything other than fresh new wire and crimps and never had any issues. If you're concerned about shorting then by all means put some heat shrink over the crimp, but IMHO things shouldn't be moving around to cause shorts in the first place!
This is is just my experience and thoughts BTW!
Charlie_Zetec
posted on 5/2/18 at 02:28 PM Reply With Quote
I'd second this. Having built/rebuilt a few Land Rover Defenders, I've used standard crimps without anything down to the wires, and never has any issues. Standard LR connectors are usually bare brass nipples (hehe) that you crimp on, and seat in a 2- or 4-way connector block. Sometimes for the really old ones, or those taken into water or mud repeatedly, the occasional removal and contact cleaner is used.
For additional wires added in or changed, a standard butt (hehe, again) crimp will suffice. For wiring that is in directly in contact with the elements, I used butt crimps with heatshrink/glue lining that come as standard, but you can just as easily use a bit of heatshrink sleeving over the top.
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
TRX
posted on 5/2/18 at 02:34 PM Reply With Quote
> phone ... gel
A telco guy gave me some crimp-on terminals once. They were filled with translucent goo. I thought it was "dielectric grease", but he claimed it was plain old petroleum jelly.
I've used petroleum jelly ever since. Decades later, moving wiring around, those crimps were still bright copper inside.
[Edited on 2/5/2018 by TRX]
Angel Acevedo
posted on 5/2/18 at 08:09 PM Reply With Quote
Originally posted by TRX
> phone ... gel
The stuff on those boxes was definitely not petroleoum Jelly (Vaseline)
It looked and felt like the stuff Gummy Bears are made of, although a little softer, but crystal clear.
Now, considering your experience and being vaseline so cheap and readily available, that would be the rtuff to use.
One last consideration is that vaseline will attack some plastics.
Regards all.
AA
