Author: Subject: top speed issues (landrover) - Solved
Mr Whippy
posted on 5/2/18 at 01:14 PM Reply With Quote
Wondering if anyone has some idea's. My old series landy is behaving badly when pushed on the main roads. As I get near it's flat out speed of 55mph it starts lurching back and forwards followed by several very loud back fires (scared the life out a passing freelander), even at lower speeds the engine seems to be hunting and not running at a constant rpm, I can feel and hear it in the gearbox whine.
It's got the usual half baked webber single choke carb which I took completely apart from the emulsion tube which I can't get to come out, all the other jets where clean. I tried banging it upsides down of the work top but it wouldn't budge, any idea's on how to get that jet out????
The ignition is electronic and I think is fine as I had the strobe on it and it ran very well when it went back on the road. I've got quite a few hills around me and it's really getting annoying........
Cheers, in advance
[Edited on 5/2/18 by Mr Whippy]
[Edited on 6/2/18 by Mr Whippy]
HowardB
posted on 5/2/18 at 01:43 PM Reply With Quote
have you checked the springs on the multi-link accelerator contraption,... I know that without one of the springs it flops about and might cause the issues you mention,..
HTH
Howard
Mr Whippy
posted on 5/2/18 at 01:50 PM Reply With Quote
yeah good call but I've check that all for backlash and its all tight. I'm not moving my foot as it's hard on the floor...
HowardB
posted on 5/2/18 at 01:55 PM Reply With Quote
mine was exactly the same - foot to the floor - 50mph on the flat and 71 down hill, not that it was possible to read the wildly gesticulating speedo!
one other area might be rear oil seal leaking oil onto the clutch, but that would smell nice too
good luck - keep us updated
Howard
cliftyhanger
posted on 5/2/18 at 02:40 PM Reply With Quote
Is the timing advancing up correctly? My Toledo (Triumph) with TR7 engine had a knackered dizzy that only worked on vac advance. The extra 16 degrees it now has is working miracles!
Mr Whippy
posted on 5/2/18 at 02:59 PM Reply With Quote
brand new electronic sensor one. The vacuum advance seems to make a huge difference to the strobe set timing even at low idle when I reconnect the vacuum hose, not 100% sure its the right curve but seem no way to adjust it. Like I say it was running very well and nothing looks wrong with the distributer
Agriv8
posted on 5/2/18 at 03:48 PM Reply With Quote
Whippy bit more info
How long has it been doing it ? contaminated fuel ?
Is it only ever in top gear does it do the same at full chat in any gear ?
Rust & Crap in tank blocking up pickup.
inlet valve not seating ? all spark plugs similar colour brown deposits !!
Coil breaking down not giving enough oomph so spark plugs are being blown out at full chat.
strange one Ignition electrics ( coil feed ) clean contact and not earthing somewhere out blew a back box up an a 2a LWB once.
ATB Agriv8
Dingz
posted on 5/2/18 at 07:38 PM Reply With Quote
I used a small ezeeout (stud remover thing) to get one out in the past.
went on and on.
perksy
posted on 5/2/18 at 08:10 PM Reply With Quote
Have you checked the carb with the air filter off to make sure that you are really getting full throttle ?
Fuel pressure ok ?
[Edited on 5/2/18 by perksy]
Mr Whippy
posted on 6/2/18 at 07:21 AM Reply With Quote
ok its all sorted now and running perfectly
Took the carb apart again, got the emulsion tube out with some help from a blow torch but it was clean. Checked the timing again with the strobe and it is rock solid stable exactly on the mark.
Only thing left was the fuel filter between the pump and the carb. It was one of those clear plastic ones you can see the orange filter inside, it's only a couple of months old, however when I tried blowing through it, it was very hard, was just fine when bought and seemed the right size. However I think it's quickly choked up with fine sediment from the tank and the cheap paper element couldn't cope so was starving the engine of fuel.
I just happened to have a newer style large modern metal can filter which was quickly swapped out and immediately it seemed to have 20bhp more, got up to the fastest top speed ever in it and even had to slow down for the speed cameras! Running as sweet as can be now just in time for playing in the snow outside
Oh well, there's a reminder to check the obvious things first before pulling stuff apart....
Thanks for the help
