New Topic New Reply
Author: Subject: High heat protection barrier ideas needed
number-1
posted on 17/2/18 at 05:12 PM Reply With Quote
Afternoon all
Does anyone have any knowledge of something i can use to go between my exhaust headers and coolant pipes to prevent the headers damaging them? They are very close/touching and its too tight an area to re route the coolant pipes. Its a BEC. Ive heat wrapped the headers but need additional protections.
Ive considered the heat fabric that you find on the inside of a bike fairing but dont think its suitable for direct contact?
Any ideas?
N1
Andy B
posted on 17/2/18 at 05:34 PM Reply With Quote
I am afraid that if the pipes are or are virtually touching you will have to re route the hoses - it doesn’t matter what you wrap, coat or apply - that condition simply will not work long term and will fail
Sorry to be the bearer of bad news but those pipes need to be well away from the headers
Best regards
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Andy+B 's Aim
number-1
posted on 17/2/18 at 05:47 PM Reply With Quote
Cheers for the reply Andy.
I will look again tomorrow with fresh eyes and see what i can come up with.
Would using Ali coolant pipes where it is touching or very close be any good?
Andy B
posted on 17/2/18 at 05:53 PM Reply With Quote
Using Ali for as much of the coolant runs as possible is the way forward
Each run works like a mini radiator dispersing heat
However
If it’s that close it will work the other way round soaking heat
What engine/chassis do you have
Send me some shots to sales@abperformance.co.uk
I’ll take a look and see what could be done
We can bend alloy tube to pretty much any shape to achieve clearance and bead roll ends ready for hose joiner
Hope that helps
number-1
posted on 17/2/18 at 05:59 PM Reply With Quote
Andy, top man. I will try to send some images tonight
Its a Roadrunner Racing SR1 with an R1 5vy engine.
Andy B
posted on 17/2/18 at 06:03 PM Reply With Quote
Ah ok - it’s going to be tight but we’ve plumbed tighter
Send me the photos and we will come up with something for you
We have done a fair few single seaters and they normally involve some thinking outside the box
posted on 17/2/18 at 08:13 PM Reply With Quote
Ceramic fibre blanket?
Visit China. Meet the child that made your trainers.
snapper
posted on 17/2/18 at 10:42 PM Reply With Quote
There are 3 methods or heat transfer convection, conduction & radiation, with your setup you are providing the best you can get for all 3.
If you can get an air gap between the exhaust and the coolant pipes you then have an option to wrap, shield and ventilate.
A heat shield can be coated with a reflective surface to help.
It’s often about using multiple solutions to achieve a greater effect.
I eat to survive
I drink to forget
I breath to wee my ex wife off (and now my ex partner)
Bladerunner
posted on 18/2/18 at 04:34 PM Reply With Quote
Heat
Try https://www.agriemach.com/c7-heat-and-sound-insulation They do a floor and tunnel insulation that will work with temps up to 1,750, that's pretty hot.
Adventure before Dementia
posted on 18/2/18 at 10:15 PM Reply With Quote
That's only half the story, all that says to me is that the material does not melt when in contact with those temperatures, it does not tell the how much heat it passes through, for that you need some numbers for thermal conductivity.
Them tiles stuck to the underside of the space shuttle is what you need., hence my suggestion of looking at ceramics.
Sorry I don't have any expertise in this area so you need to do the research yourself.
Angel Acevedo
posted on 19/2/18 at 03:36 AM Reply With Quote
Deja vu..
Look for Stratoflex hose insulation....
It is used in jet engines.
New Topic New Reply
