Author: Subject: Engine for sale
plutos3
posted on 18/2/18 at 02:55 PM Reply With Quote
Engine for sale
Nissan CA18det engine
Note This engine was only rebuilt as the piston had detonation damage.
The block is bored and comes with new Woosner pistons
The crankshaft is standard and has been checked.
Comes with
Steel con rods (new)
ACL race bearings for Mains and big ends (new)
Genuine oil pump (new)
Genuine gasket set (new)
ARP head stud kit (new)
ARP flywheel bolts (new)
XTD light weight flywheel (new)
XTD stage 3 clutch (new)
Gates racing timing belt (new)
Vernier camshaft pulleys x2 (new)
Balanced by Agra engineering Dundee.
The sump has been winged for extra oil capacity (used)
Stainless steel exhaust manifold (used)
Cylinder head has been skimmed
Genuine Nissan oil filter (new)
Graphogen assembly grease (new)
Engine is complete except turbo and coils
Genuine Nissan work shop manual
£1850
This was in my kit car running but removed for rebuild.
There is a 5 speed gear box with brand new quick shift available septate if required
