Ivan
posted on 21/2/18 at 08:56 AM |
Exhaust Gasket Temperature Range
I need to get a flange gasket cut to fit between exhaust sidepipe and exhaust manifold. What temperature gasket material should I request - it will be
about 18" from the head. The suppliers have suggested 450 deg C material but I just want to check. My gut feel says closer to 650 deg but that
will increase the cost.
40inches
posted on 21/2/18 at 09:04 AM |
At 18" from the head 450 degrees will be fine. Mine are around 12" and I used ordinary household silicon sealer as a seal. 1000 miles on
and it's still sealing
