Author: Subject: Rover V8 megasquirt map.
r1_pete
posted on 21/2/18 at 11:14 AM Reply With Quote
I have my V8 starting, fast idling, warming up ok and ticking over strong.
I have a hesitation pressing the throttle from idle, does anyone have a Megasquirt RV8 map I can take a look at see how no load pickup is handled in the fuel table.
40inches
posted on 21/2/18 at 01:20 PM Reply With Quote
This is acceleration enrichment? Could never get my head around this! Stopped it stuttering/stalling by running VEAL with the lower threshold 100RPM above idle then doing a lot of standing starts from idle either on the drive or actually driving.
Should say that this was with moderate pedal movement speed, never got it right when stamping on the pedal, but once it was over 1500RPM was okay.
[Edited on 21-2-18 by 40inches]
r1_pete
posted on 21/2/18 at 03:07 PM Reply With Quote
Cheers Dave, Iíll have a play, Im thinking Iíll just go richer at the top of the table until the hesitation is gone, I was leaving AE alone as per Philís (extraefi) manual.
Must master ve analyse though....
froggy
posted on 21/2/18 at 08:52 PM Reply With Quote
Is it using a wideband 02 ?
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
r1_pete
posted on 22/2/18 at 10:00 AM Reply With Quote
Yes mate, Im running a wideband.
froggy
posted on 22/2/18 at 02:12 PM Reply With Quote
I drove mine around with ae turned off and let it sort itself out . Steady throttle application and it was pretty close after a couple of hours , turned the ae back on and it drove fine just needed a few tweaks on the Dyno
