jps
posted on 22/2/18 at 09:52 AM |
Earthing in car wiring, have I understood?
I will be moving onto wiring before too long, and have basically not wired anything since my Hornby 12v train set 20 years ago.
I have seen lots of mention of 'earth' in posts about switching arrangements.
Am I right in thinking that 'earth' points in kit car wiring are really about routing the current across to the chassis.
And that the -ve terminal on the car battery is just connected across to the chassis.
So the 'earth' connections are ways of completing the circuit?
cliftyhanger
posted on 22/2/18 at 10:11 AM |
Yes, in short.
Just look under the bonnet of a tintop (assuming you can see the battery!) there is a whopping big earth/neg lead attached to the body. You just
attach to chassis instead. Just make sure the cable is big enough, and the connections are all good with paint/powdercoat cleaned off. Poor earth is a
real curse.
JMW
posted on 22/2/18 at 11:19 AM |
Ensure the engine has a good short connection to the battery negative as well, lack of a good connection causes problems starting for example.
CTLeeds
posted on 22/2/18 at 11:51 AM |
Definitely have at least one if not two separate earth straps between the engine block and the chassis. Make sure these connections are via an
unpainted part of the chassis to avoid any insulation. Dressing these terminations can always be done after testing the engine runs well. A cheapo
multimeter will prove you have good earth between the block and any exposed part of the chassis.
Regards
Chris
jps
posted on 22/2/18 at 02:42 PM |
Is this because some components are 'earthed' onto the block? For example the alternator or starter motor perhaps?
CTLeeds
posted on 22/2/18 at 03:23 PM |
Exactly that!
Chris
gremlin1234
posted on 22/2/18 at 05:48 PM |
if you are using an ecu, many (most) sensors usually have an explicit 0V wire to the ecu
