Author: Subject: A few bits - Garage clearout
tims31
posted on 9/3/18 at 03:00 PM Reply With Quote
Have a bit of a clear out in the garage so these bits are offered before they get thrown out if anyone wants them.
Pair of 5 3/4" headlamps with side light. E marked and H4 marked - Only fitted for a few months as now upgraded to LED lamps.
Come without the ring and backing housings but can be bought from SVC for £38. Have the extra bright halogen bulbs fitted too. One of the side light rubbers has a slight tear in it but holds the bulb fine.
£30
Sierra steering wheel - Does not have the slipper ring as I still have that fitted to my hub. The centre cap has one of the plastic tabs broken off but I made a metal clip to hold it in and passed IVA with it just fine, can't be seen once fitted in the wheel.
£10 - SOLD
Sierra 1.8 Sapphire master cylinder and reservoir with level warning cap.
£10
various lengths of 32mm silicone hose £10 the lot
450mm -
370mm -
2x150mm
2x60mm - SOLD
Not sure if this is of use to anyone - Sierra 1.8 CVH distributer cap and rotor arm.
All items are plus postage
[Edited on 10/3/18 by tims31]
[Edited on 11/3/18 by tims31]
Build: http://www.martinsfurybuild.co.uk/
starterman
posted on 9/3/18 at 09:25 PM Reply With Quote
Can I have the steering wheel please. PM me some details and I'll sort some shillings out if that's ok.
Mike
tims31
posted on 9/3/18 at 11:39 PM Reply With Quote
U2u sent
Just need to weigh it for postage.
wowblaauw
posted on 10/3/18 at 08:03 AM Reply With Quote
Hi, I’ll take the hoses, please pm me the details. Thanks, Craig
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming...
Damn, What a ride!!"
simon h
posted on 10/3/18 at 12:06 PM Reply With Quote
If you can do £30 posted for the headlamps I'll have them.
Cheers Simon
tims31
posted on 11/3/18 at 06:29 PM Reply With Quote
Cheers Simon
Yep okay, U2u sent
tims31
posted on 14/3/18 at 11:35 AM Reply With Quote
headlamps, Steering Wheel and hoses all sold
Anyone interested in the master cylinder or dizzy?
JonBowden
posted on 16/3/18 at 01:15 PM Reply With Quote
I might be interested in the master cyl.
Do you know what bore it is?
Jon
tims31
posted on 16/3/18 at 02:08 PM Reply With Quote
Hi Jon,
Having had a look and researched the numbers I think it is 22.22mm. Was fitted to a Ford Sierra Sapphire 1990 1.8CVH
HTH
