Author: Subject: Fuel Leak - 2.0 Zetec on Jenvys
Double R
posted on 15/3/18 at 07:39 PM Reply With Quote
Evening fellas,
I've just put the car back on the road for spring(GTS Panther) and it's leaking fuel everywhere on tickover.
It's running a 2.0 blacktop with Jenvey 45's and a swirl pot with twin pumps.
It starts, runs and revs exactly as it should, but there's a small leak from the connection to the front of the fuel rail, and there's a large leak from the last injector to cylinder #4.
I've rebuilt the fuel line, injectors and pipes and it's still leaking on tickover, but it stops under load.
Any ideas what this is? Faulty pressure regulator or pump?
Thanks in advance!
tims31
posted on 15/3/18 at 07:57 PM Reply With Quote
Did you change all the seals for new ones?
Build: http://www.martinsfurybuild.co.uk/
Double R
posted on 15/3/18 at 08:28 PM Reply With Quote
Yes, re-balanced the injectors with new seals all round.
CosKev3
posted on 15/3/18 at 10:54 PM Reply With Quote
What's changed/been worked on over winter?
It was fine last time you had it out?
tims31
posted on 16/3/18 at 02:02 AM Reply With Quote
I guess if it goes away when you up the load then I would say maybe the fuel regulator is providing too much fuel, can you test the pressure in the line?
Double R
posted on 16/3/18 at 10:24 AM Reply With Quote
This is the odd thing, it went under the covers in November, all working the way it should.
I started it this week for the first time and this is where the fuel leak started.
I think it must be the fuel regulator, potentially failed or needs adjustment as it looks like it's putting too much pressure into the line.
I'll have a look when it stops raining!
jeffw
posted on 16/3/18 at 11:27 AM Reply With Quote
Fuel pressure gauge, the thing virtually no one fits but makes this type of fault finding simple. Also don't use adjustable fuel regulators, buy a decent quality fixed pressure one (Bosch etc) and fit & forget. All this adjustable ones are a waste of time and money.
[Edited on 16/3/18 by jeffw]
Double R
posted on 16/3/18 at 01:04 PM Reply With Quote
Yes good shout, I'll check it and if required source a replacement one over the weekend......... plus a pressure gauge
Cheers all
RR
CosKev3
posted on 16/3/18 at 01:21 PM Reply With Quote
Give it a tap with a small hammer,atleast if that stops it you know it's dodgy.
Is the injector leaking the nearest one to the regulator?
[Edited on 16/3/18 by CosKev3]
Double R
posted on 18/3/18 at 07:35 PM Reply With Quote
I'm still waiting for the snow to clear before I can check it.
But yes, the biggest leak is coming from the injector nearest to the regulator.
Does that indicate it's pushing too much pressure?
RR
CosKev3
posted on 18/3/18 at 07:52 PM Reply With Quote
RR
Could well do yeah,as the regulator is at the return end of the rail
