Author: Subject: Master cylinder sizes brakes and clutch question
will121
posted on 25/3/18 at 05:45 PM Reply With Quote
What master cylinder sizes should I go for in a bias adjustable pedal box with;
Front brakes - wilwood powelite 4 piston 1.38" dia
Rear brakes - cosworth calipers
Clutch - rx8 hydraulic actuator
[Edited on 25/3/18 by will121]
Angel Acevedo
posted on 9/3/19 at 02:23 PM Reply With Quote
Which sizes did you used at the end?
I have 2 each 0.7" and one each 0.625"
Trying to decide on initial set up too.
Thanks in advance.
AA
will121
posted on 9/3/19 at 05:51 PM Reply With Quote
Ended up buying a new floor mounted peddle box kit from ODP that came with .75 clutch, .7 rear, .625 front, but it's not up and running yet so can't confirm how well it works
