Author: Subject: 200bhp Rover K series - Dry Sump - Gearbox etc
Waitey
posted on 27/3/18 at 10:47 AM Reply With Quote
Rover 1800 K Series
·         Scholar Evo 2 block
·         Omega forged pistons
·         REC valves (26/29.5mm) with Colsibro guides
·         Head modified under watchful eye of DVA Power
·         Solid lifters with shims
·         Piper 285 cams with vernier wheels
·         EU3 head with wasted spark dual ‘coil on head’
Jenvey Direct 42mm to Head Throttle Bodies with ITG filter
Emerald K6 ECU - 315cc injectors
200bhp @ 8000rpm 150lb/ft @ 5500rpm
£3500
Also availble:
Dry sump - Pace alloy sump, pump (2 x scavenge, 1 x pressure) - £595
Powerspeed 4-2-1 all stainless exhaust and manifold (Caterham/Westfield Fitment) - £595
Titan Bell Housing, QED flywheel Helix Clutch (K series to type 9) - £500
Quaife alloy Type 9 with Straight cut, close ratio 2.04, 1.54, 1.21, 1.0, 0.87 gears - £2000
All rotating and reciprocating parts were balanced by Steve Smith at Vibration Free
Over £10000 in parts alone. Most recent mapping session was in Sept 2017.
Will be avaible from 29th March 2018
[Edited on 27/3/18 by Waitey]
305bhp All Steel Duratec Westie
Waitey
posted on 27/3/18 at 10:55 AM Reply With Quote
Engine now has a deposit on it!
Still available:
Waitey
posted on 27/3/18 at 02:38 PM Reply With Quote
Dry sump sold.
Mark RSP
posted on 24/1/20 at 07:16 PM Reply With Quote
Long shot but did the exhaust manifold sell ??
